Author Topic: DIY Oil Change  (Read 5621 times)
Offline Imjustsid
DIY Oil Change
« on: 28 February 2017, 13:08 »
Sorry guys might be a bit of a stupid question! I am looking at changing the oil myself (being cheap i know) I've been told that its fairly easy to do as long as you change the sump nut.
However i am unsure which oil i should be using, Castrol Edge 5W30 LL or Castrol Edge 5W40?
I was hoping some one could explain and point me in the right direction?
Also how much oil do i need? (I dont want to do the oil change and realise i dont have enough!)
Owned the GTI for 6 months now got to say one best cars i've owned!
Thanks in advance
Sid
Offline lemski
  • 16v
Re: DIY Oil Change
« Reply #1 on: 28 February 2017, 13:17 »
Ring a motor factors and give them your reg and theyll give you all you need. They may ask if you want longlife poil or bot but that depends on if you want that or not
Offline monkeyhanger
Re: DIY Oil Change
« Reply #2 on: 28 February 2017, 13:39 »
I did a "run-in" DIY oil change on my R - it was a complete doddle. If I remember rightly, the car took 5.6L of oil to the top of the checked markings of the dipstick, the oil filter was about £13 and the new plastic sump nut/plug was about £2.30. There are little green paint marks applied to the filter housing and housing base that line up to know you haven't overtightened it. Castrol Edge or Mobil 1 fully synthetic 0W40 or 5W40.
If your car is under warranty I would not recommend a DIY oil change in lieu of a proper service you'll be required to have proof of to maintain your warranty.
mattwilko92
Re: DIY Oil Change
« Reply #3 on: 28 February 2017, 13:40 »
Thanks in advance
Sid
Either oil is fine as long as it meets the VW 504/507 spec. You need roughly 5.7 litres. Although I purchased a sump plug I ended up reusing the old one as it showed no damage. Oil filter uses a 32mm socket and should be torqued to 25nm (but +5nm is fine).
Offline brettblade
Re: DIY Oil Change
« Reply #4 on: 28 February 2017, 16:06 »
Thanks in advance
Sid
QFT - though I'd recommend changing the sump plug in all instances as it's plastic.
Orded 04/06/2016
Build W/C 01/08/2016
Handover 01/09/2016
GTI PP, CSG, Tech pack, parking pack, 90% tints, DCC, 19" Santiago alloys
Soon to be gone!
7.5R Indium Grey, 19” Spielbergs expected 01/03/2019.
Offline Imjustsid
Re: DIY Oil Change
« Reply #5 on: 28 February 2017, 20:57 »
Thanks for advice guys!
Wheres the best place to buy a genuine filters and sump plug apart from the dealers?
We have place called TPS in manchester, not sure if any one knows of any others.
Offline Mr GTD
Re: DIY Oil Change
« Reply #6 on: 28 February 2017, 22:25 »
This may be of use...http://www.golfmk7.com/forums/showthread.php?t=3002
TPS would be your best bet but they like there part numbers so link above should help.
« Last Edit: 28 February 2017, 22:27 by Mr GTD »
Offline phope
Re: DIY Oil Change
« Reply #7 on: 28 February 2017, 22:48 »
Get a Pela oil suction pump and extract it via the dipstick tube
https://www.amazon.co.uk/Pela-6000-Oil-Pump-Extraction-x/dp/B002EJ2GUC
Quick, efficient and a lot less mess than fiddling around with sump plugs and jacking the car up
Pros & cons of both methods:
https://humblemechanic.com/2014/08/15/draining-engine-oil-vs-extracting-engine-oil/
« Last Edit: 28 February 2017, 22:56 by phope »
Golf Mk8 R order cancelled...awaiting company car instead
Tiguan 1.5 Elegance for the wife & dogs
Skoda 1.5 SEL cheap lease special
mattwilko92
Re: DIY Oil Change
« Reply #8 on: 01 March 2017, 07:54 »
Not wanting to start a debate. But when I changed my GTI's oil for the first time I did find bits of metal in it from 'running in'. I don't believe these would get sucked out using an extractor.
Offline juggler
Re: DIY Oil Change
« Reply #9 on: 01 March 2017, 09:21 »
There are guides on Youtube if you're interested..
1976 Mini 1275GT
1983 MK1 Fiesta XR2
1988 Escort RS Turbo
1996 MGF VVC
2001 E46 2.5 Conv
2002 Impreza WRX
2004 E46 M3
2012 500 Abarth
2013 Punto EVO Abarth Supersport
2016 MK7 GTI
