Author Topic: Gearbox oil change makes massive improvement  (Read 8976 times)
Offline prt57
« on: 26 February 2017, 08:27 »
I have had my 1.8t since new in 1998. Even back then the gearbox was a bit notchy going from first to second. Worse when cold. In fact it was the only disappointing thing about the car. Fast forward to the middle of last year and I noticed an oil leak from the oil seal where the driveshaft enters the box. I used a local transmission specialist who did a very good job. As the car had done over 100,000 miles I asked for a gearbox oil change. They used a Castrol oil spec that matched my Haynes manual.
Afterwards I started to notice that it was very difficult to go from first to second or third to second or even engage first gear unless totally stationary. However, all seemed OK when the car had warmed up thoroughly. Internet research pointed to the oil that had been added.
So as part of a oil change service at a VW main dealer I asked for a gearbox oil change with genuine VW oil. Interestingly they could not give me a price straight away as it is not normally done.
It really seems to have done the trick. It took a few miles for the new oil to fully circulate and disperse the remaining Castrol oil from the components but I could even say that the gear change is now better than new and the car is at 113,000 miles.
As a word of caution, the VW mechanic either cross threaded or over tightened the engine sump plug stripping the thread when changing the engine oil. They admitted it straight away and paid for a new sump pan. I took the opportunity to pay for a new oil pick up pipe. Peace of mind really as there was no blockage but it shows the benefit from using fully synthetic longlife oil for the total life of the car.
Offline prt57
Re: Gearbox oil change makes massive improvement
« Reply #1 on: 03 March 2017, 08:35 »
Just an update, I have now done about 600 miles since the gearbox oil change and the gear changes are now exactly as I would expect even when cold.
I read somewhere that the original oil specification changed since my car was made in 1998 and so this new oil is much better.
So if you have trouble changing 1st to 2nd, 3rd to 2nd or even engaging 1st gear unless you are totally stationary when the engine is cold this winter, this oil change could help you too. Remember, you need the latest spec  VW oil for your car.
Offline Zack
« Reply #2 on: 03 March 2017, 09:53 »
Interesting post, thanks. Credit to the dealership that admitted stripping the thread, many would have kept quiet about it, who is the dealership?
Offline pulsar
  • golf mk4 tdl 150 best golf ever
« Reply #3 on: 03 March 2017, 20:45 »
hi
nice idea Ive had my mk4 7 years  fantastic 6 speed box apart from 1st gear  it is a notch y gear, luckily enough its a re mapped  tdi 150 so pulls off in second  :grin:
tdi 150   Remap/de-cat
  NM Torque  480
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 04 March 2017, 20:43 »
Do you know what oil they used? This is on my list of jobs to do once the weather warms up
Offline bgbazz
  • If it aint broke...I can fix it!
« Reply #5 on: 05 March 2017, 17:57 »
I'd like to know what grade and brand they used too. Mine is going in for a full service this week and info would be most helpful...engine oil, filters, coolant and the Haldex system oil all sorted, but curious regarding gearbox oil.
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 05 March 2017, 20:37 »
General consensus seems to be 75w90 oil that meets or exceeds GL4
I've got a mate who works at VW looking into it tomorrow for me so I'll have an idea on costs although this will only be in GBP
Offline bgbazz
« Reply #7 on: 06 March 2017, 08:09 »
Thanks Wazzzer, that grade of oil is easy enough to obtain over here, so no probs with GBP issue.
I'm still interested to hear from prt57 about what oil they used in his car.
 :smiley:
Offline prt57
« Reply #8 on: 06 March 2017, 15:29 »
Hi there,
Thanks for all the interest and replies.
The oil put in by the transmission specialist was Castrol 75w 90. This was the oil that made changing a nightmare until fully warmed up.
The  VW garage used the current VW specification for my 1.8T from 1998. I tried to find the rating but none of the parts people had access to that sort of information. I think it must be thinner than 75w 90 bacause that rating of oil only gave a satisfactory gear change when it was warm and thus thinner.
So don't bother trying to find a non VW oil as for the money it has solved my cold change gear box issue. I wish I had done this years ago.
Offline bgbazz
« Reply #9 on: 07 March 2017, 10:18 »
Cheers for the update.
 :smiley:
