Author Topic: Gearbox oil change makes massive improvement  (Read 8957 times)
Offline gazareth
Re: Gearbox oil change makes massive improvement
« Reply #10 on: 07 March 2017, 23:58 »
I just mixed up a litre of 80/90 with a litre of atf :nerd:. works great in any weather. that's in a mk2 though :wink:
Offline bgbazz
  • If it aint broke...I can fix it!
« Reply #11 on: 08 March 2017, 04:46 »
That's a trick used by a lot of Jeep owners as well...probably not in the 50/50 ratio though.
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
Offline gazareth
« Reply #12 on: 11 March 2017, 13:26 »
yeah, it's all done to how the owner uses the vehicle really. a lot of 4x4 drivers don't really push them that hard or don't go off-road, so they can get away with a thinner oil, and improve their fuel economy to :nerd:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 14 March 2017, 20:06 »
A bit more information I have discovered while trying to find the correct oil for the Golf - make sure the oil is 75w90 grade and conforms to the GL-4 specification, NOT the GL-5. This is possibly the reason for the problem with difficult gear changes that are described above
« Last Edit: 14 March 2017, 22:21 by Wazzzer »
Offline prt57
« Reply #14 on: 17 March 2017, 07:33 »
As I mentioned earlier, just use the genuine VW oil. The cost savings and potential hassle don't make searching for something else worth while. I had considered getting rid of my 1.8T because the gear change was so poor when cold. No issues at all now with gear changing and so by the end of this year I will be into 20 years of ownership. I am amazed at the difference the correct oil makes.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 17 March 2017, 19:20 »
Approx £8 a litre if anyone is getting it from the dealers :afro:
