Author Topic: earthing point for sub in the boot of mk3 golf  (Read 3018 times)
Offline Robbie_18
« on: 01 October 2005, 22:43 »
hi,
this may sound really dumb but i've just wired up a sub into my gf's mk3 golf but i cant find a gd earthing point in her boot any one got any sugestions?
Offline the beast
Re: earthing point for sub in the boot of mk3 golf
« Reply #1 on: 02 October 2005, 21:10 »
yap  :rolleyes: the triangle mount screw by the boot light my amp earth there  :tongue:
Offline HARDCOR3
« Reply #2 on: 02 October 2005, 21:12 »
or 1 of back light bolts.....
Offline j_s
« Reply #3 on: 02 October 2005, 23:42 »
Or get a drill out and make one, go for somewhere quite solid, away from petrol tank, important bits of the car. Then rub a bit of the paint off around the hole, use ring terminal/bolt/nut and it's done  :smiley:
I did it today in my wheel well, also put a washer either side to stop water getting through, covered the underside in anti rust treatment and sprayed it in waxoyl  :grin:
James
Offline Nickyb
« Reply #4 on: 05 October 2005, 16:38 »
Just done mine.
Lift up the off side (driver side) rear seat up, you should find an electrical black box which is earthed allready, god knows what it is, looks important though! You can unscrew that and earth it there, nice and easy.
Smooth Corrado
« Reply #5 on: 05 October 2005, 21:42 »
I always use the rear seatbelt bolts that go through the floor. Never had any problems with alt noise from their either  :smiley:
