Author Topic: Low coolant  (Read 6373 times)
Offline Booth11
Re: Low coolant
« Reply #10 on: 13 January 2017, 12:58 »
The service guy said something about some GTD's coming from factory have had an air lock problem which has caused a similar problem with the coolant, how true that is im not too sure.
This has been recognised as an issue and documented on other forums.  Apparently due to an inability to be able release air from the system at the factory, this air later fully bleeds out of the system several thousand miles on the clock (around 8-10k) and appears to look like a loss of coolant as the escaping air leads to a drop in the coolantl reservoir.  If this is the case, top it up and should be ok.
Other common culprit of an actual leak is the water pump.
« Last Edit: 13 January 2017, 14:33 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline fredgroves
Re: Low coolant
« Reply #11 on: 13 January 2017, 13:11 »
That sounds like a definite explanation of what happened.
Offline vw spur
Re: Low coolant
« Reply #12 on: 13 January 2017, 18:01 »
Thanks Booth, you've kind of put my mind at rest now you've said you've heard of that issue too, I didn't know if the service adviser was just spinning me a line. The car is booked in now so I'll take it in and just let them give it the once over, at least then it'll be on the system as having been in just in case something happened further down the line.
Collected 09/04/16 : Golf GTD Carbon Grey Sport & Sound Pack DSG Pro Nav Dynaudio Rear Camera High Beam Assist 90% Tints
Still pining for:2009 BMW 330i M Sport Convertible
Offline Mark V GTD
Re: Low coolant
« Reply #13 on: 13 January 2017, 19:31 »
I topped mine up with some of the pink fluid after about six months. Never moved after that.
Offline GTI_Ant
Re: Low coolant
« Reply #14 on: 13 January 2017, 21:00 »
Exactly the same with mine. The dealer had a technical note from VW that stated the air lock issue during manufacturing and could occur during the first 15K miles or so. They topped it up and said to keep an eye on it just in case there's something else going on.
GTi Clubsport DCC winter pack rear camera
Previous:
7.5R 3dr DSG DPB Prets Dynaudio
MK7 GTI PP Tungsten Silver Manual Nav Dynaudio Winter Pack Park Assist
Offline Watts
Re: Low coolant
« Reply #15 on: 13 January 2017, 22:47 »
An airlock was going to be my next suggestion. But you all sneaked in while I was at work :wink:
Previously:
Offline linc-dub
Re: Low coolant
« Reply #16 on: 14 January 2017, 09:22 »
My 63 plate GTD had sudden coolant loss and checked on the forums ref air lock and it never happened again during 30,000 miles of ownership.  10,000 miles in with my 65 plate GTD and the same thing happened, so topped it up and its been fine since.  Similar problem has occurred with some Audi's that work colleagues own and it does appear to be a VAG trait!  Yes if you suspect / have other signs of an actual leak obviously best to get it checked out at the dealers.
Picked up 02.09.17 Mk7.5 GTD Isaac Blue, Manual 5 Drs, DCC, Reversing Camera, Keyless, 90% tints, Heated front screen, Mudflaps all round
Sep 2015 65 plate Mk7 GTD Carbon Grey, Manual, 5 Drs, DCC, Reversing Camera, Sat Nav, Keyless, Sport & Sound, Mudflaps all round
2013 63 plate Mk7 GTD, Manual, 5 doors, Carbon Grey Metalic, ACC, Reversing Camera, Mudflaps front & rear - Took delivery October 2013
Offline C3PO
Re: Low coolant
« Reply #17 on: 14 January 2017, 15:06 »
Exactly the same as mine, and never moved since
Mk6 GTI, 18" monza shadows, Leather, Bluetooth Phone - gone
Mark 7 R, 19" wheels, lapiz blue, 5 door, leather, reversing camera - gone
2018 Audi S5 Sportback, pano roof, LED Headlights  B&O sound system - gone
Current 2020 Golf GTI TCR, pure grey, pano roof , 90% tints and Akrapovic exhaust.
Offline p3asa
Re: Low coolant
« Reply #18 on: 14 January 2017, 16:55 »
Interesting thread as I just checked the GTD the other day and the coolant level was just below the minimum after 24k miles.
I put a slight amount in and will let the dealer fill the rest at its next service.
Offline Diehammer
Re: Low coolant
« Reply #19 on: 16 January 2017, 11:49 »
I had the same issue with my GTD @8000 miles. Garage said that it was a common issue with the engine.
Golf GTD MK7 5 door Manual, Carbon Grey, Keyless Entry, Rear View Camera.
Ordered 26/02/15  Build Week Confirmed 24/04/15 (BW21) Stage 5a 19/05/15 Stage 5b 21/05/15 Stage 5c 29/05/15 Stage 6 02/06/15 Stage 7 04/06/15 Pick Up 06/06/15
