Author Topic: Low coolant  (Read 6393 times)
Offline vw spur
Low coolant
« on: 13 January 2017, 07:28 »
I bought my GTD brand new in April 2016, I've checked fluid levels fortnightly ever since I've had it and all has been fine since I have had it, this morning I came out to go to work and as soon as I started the car the low coolant warning appeared, I checked the level straight away and it was below the minimum, would the recent cold snap have had anything to do with this or have I got a leak or something more serious to deal with??
The engine has never over heated or anything and the gauge always sits in the middle when up to temp so I'm a bit concerned as to why a new car with 8000 miles on the clock should be losing coolant.
Collected 09/04/16 : Golf GTD Carbon Grey Sport & Sound Pack DSG Pro Nav Dynaudio Rear Camera High Beam Assist 90% Tints
Still pining for:2009 BMW 330i M Sport Convertible
Offline Dully
Re: Low coolant
« Reply #1 on: 13 January 2017, 08:36 »
Get it in for a check over, my MK5 GTD 170 destroyed a water pump seal with less miles on it than that, luckily I spotted a pool of coolant on the garage floor.
Driving - MK7 GTD, 5 Door, CSG, DSG, Santiago's
ashleyman
Re: Low coolant
« Reply #2 on: 13 January 2017, 09:51 »
My R did exactly the same thing at about the same age as your GTD.
I took it to the dealer and by the time I got there the fault code had re-set itself and the level was very low. I didn't have any proof of anything that the car warned of and once the car had been re-started it was low but acceptable so they sent me on my way...
It did it a few nights later and I had to top it up. Since then it's been fine (thankfully) and hasn't shown any more faults, errors or required topping up.
Offline Watts
Re: Low coolant
« Reply #3 on: 13 January 2017, 09:52 »
Level down = leak. Get it to your dealer asap. No point taking chances and don't top it up either - that's your evidence so they can't ignore it!
Previously:
Offline Finglonga
Re: Low coolant
« Reply #4 on: 13 January 2017, 10:38 »
There have been a few with thermostat housings that have needed replacing including myself. Don't leave it below minimum, top it up and have a word with the dealer. There will be tell tail stains on the engine where the leak is.
Offline fredgroves
Re: Low coolant
« Reply #5 on: 13 January 2017, 10:39 »
You say its a leak, but mine did it once, I topped it up and since then its never come back.
I was expecting to find it used it regularly, but coming up to three years, its only happened once.
Offline TwoSheds
Re: Low coolant
« Reply #6 on: 13 January 2017, 10:51 »
Same experience as you..
Offline Watts
Re: Low coolant
« Reply #7 on: 13 January 2017, 11:03 »
You say its aleak, but mine did it once, I topped it up and since then its never come back.
It's a sealed system, if the level drops then it's gone somewhere. The level should not drop.
Previously:
Offline vw spur
Re: Low coolant
« Reply #8 on: 13 January 2017, 11:47 »
Thanks everyone, I've just been onto the local dealer and I've booked it in for Tuesday for them to have a look at it, they aren't the supplying dealer as I don't fancy a 50 mile trip to where I bought it.
The service guy said something about some GTD's coming from factory have had an air lock problem which has caused a similar problem with the coolant, how true that is im not too sure.
I'm going to leave the coolant level as it is as I can just use the Mrs' car on Monday and the dealer is only 5 mins from the house.
Will report back with the outcome
Offline fredgroves
Re: Low coolant
« Reply #9 on: 13 January 2017, 12:48 »
I agree, but wherever it went, it never went there again.... a bit like me and Magaluf.
