Author Topic: Clubsport S Cup2 Tyres  (Read 7232 times)
Offline Sean G
« on: 08 December 2016, 22:52 »
Are any of you guys who are intending using the cars now going to change the tyres - at least until the weather is a bit milder and we don't have the risk of snow ice or frost
I've a new set Pilot Super sports here and a new set of Pilot Sport 3's and will probably fit the PS 3's until temperatures rise a bit .  I know still not ideal but I've no real need to fit winters as if it too bad I can use the other car and to be fair we rarely get a bad fall of snow.
I have a set of 18" Nokian winter tyres but would need to buy a set of rims and ideally I want to keep them and if really needed fit them into my wife's GTD.
Offline vipergts
Re: Clubsport S Cup2 Tyres
« Reply #1 on: 09 December 2016, 10:37 »
Tyres don't seem too bad or at least nothing like the tyres on my CSL
Though if I do get some different rubber I'd probably buy a set of wheels to put them on to make the swap easier
Offline wigit
« Reply #2 on: 09 December 2016, 11:21 »
I had a set of sport cups 2 on my R last year and tended to stick to the dry days, did a wet track day on them and should have put the super sports on as the slowest two cars were a 4wd R and a GT4.
You can get heat in them but when warn they just hated the wet, issue on the R is it just sends the power back to the rears which are even colder and so its even more lairy
I have a set of Michelin Alpins on my R this winter as i do 25 miles each way across back roads and have to say just loving them
Super sports did cope rather well when I finally had to take the Cup 2s off last year
Personally I'd just get a set of 18" TD Pro Race 1.2s with the super sports and then you get the best of both worlds
Offline GT4
« Reply #3 on: 09 December 2016, 13:27 »
I thought that VW didn't supply the appliances to remove the wheels with CS-S ...?
Offline monkeyhanger
« Reply #4 on: 09 December 2016, 18:57 »
In the cold weather, my Pretoria shod R is running great on Michelin PSS, in the mildly moist, the properly wet and the dry at temps as low as minus 2°C. I'm sure they'll do well for the CSS too.
Offline Clubsport S
« Reply #5 on: 09 December 2016, 19:57 »
I was initially thinking of putting some different tyres on, but have been convinced otherwise by others with Cup 2's, including some Clubsport owners.  Generally they don't appear to be too bad in the wet with the Pistonheads video of the car on a wet track day worth a watch.
I will mostly be using mine on dry days though. Think the latest ring record was set at a temp of 8 degrees so they can't be too bad at low temperature.
« Last Edit: 09 December 2016, 20:00 by Clubsport S »
Offline jjgreenwood
« Reply #6 on: 13 January 2017, 08:46 »
Well after commuting in the light snow today I've decided to put on some different rubber. It simply doesn't make sense to use low tread expensive tyres in this kind of weather so I've ordered some Yokohama Advan Sport 105's. I'll let you all know how it goes. I'll save my expensive semi slicks for the summer.
Sales Manager - Inchcape Volkswagen Swindon
VW Golf GTI Clubsport S - GO15 CSS
Offline volkswizard
« Reply #7 on: 13 January 2017, 09:59 »
I read a trustworthy review of the Cup 2 (actually it was a Pistonheads thread and the chap from Michelin who deals with these tyres was posting), apparently they are much better than the original Cup tyre and work OK on the road above 7 degrees C.
Any 'summer' tyre stops working properly below 7 degree C anyway hence why that's the temp at which winter tyres start to work.
The Cup 2 has around 5mm of tread from new so a new/less worn PSS will work better at displacing water.
Mine have been acceptable so far but when the weather is this cold and icy/slushy/snowy I don't expect any non-winter tyre to work too well.
Offline wigit
« Reply #8 on: 13 January 2017, 16:57 »
A wise man
Offline jjgreenwood
« Reply #9 on: 13 January 2017, 23:26 »
Oh I completely agree they are far from a disaster, in fact I've been pleasantly surprised by how good they are in the cold and wet. I was expecting them to be horrible. What made me decide is exactly what you point out - the fact that they can't do their thing most of the time due to the cold. The yokohama's are £116 each and the Cup 2's are £230. The Yoko's have 10mm of tread and the Cup 2's have 5mm. It simply doesn't make any sense to use the cup 2 at the time of year when conditions mean that 80% of the time they can't do their thing. May as well stick the Yoko's on, if it does snow they have twice the tread and if it is sunny then they still reasonable enough to have some fun. In may I'll stick the Cup 2's back on til late sept. No point in using up expensive rubber when its not doing its thing anyway. PSS tyres are £175 so quite a premium over the Yoko's.
