Author Topic: Brake master cylinder size  (Read 6383 times)
Offline Mattyj
« on: 13 October 2016, 15:56 »
As above for an 89 16v got home and measured with a vernier no help apparently its 22mm bore? Where is this measurement taken from?
Offline h8v
Re: Brake master cylinder size
« Reply #1 on: 14 October 2016, 07:49 »
This seems to be the correct one...https://www.vwheritage.com/shop/mk2-golf/1H1611019B/master-cylinder-mk2-golf-gti-16v-g60-t4-90-95-no-abs/?crumbStartPage=1&crumbStartRow=1
22.2mm is the diameter of the piston and bore in the middle of the thing.  You won't get to see it unless you take it all apart.
The 22mm one is both better and cheaper than the other 20.64mm mk2 master cylinder.
Offline lemski
  • 16v
« Reply #2 on: 14 October 2016, 08:21 »
If you ring up euro car partsand ask for a g60 master cylinder thats the better one. Fits direct. They may ask 2 or 4 port. If they dont itll be a 4 port but you just need two planking plugs or two bleed nipples in the ones you dont use. Well worth the upgrade though
Offline Mattyj
« Reply #3 on: 14 October 2016, 09:43 »
Thought mine had 4 but only has 2
« Last Edit: 14 October 2016, 14:23 by Mattyj »
Offline lemski
  • 16v
« Reply #4 on: 14 October 2016, 18:29 »
Yeh mk2 has 2 but g60 master cylinder has 4
Offline Mattyj
« Reply #5 on: 14 October 2016, 19:31 »
How come the g60 has 4?
Offline gazareth
« Reply #6 on: 14 October 2016, 20:04 »
what kind of difference does it make to the brake feel when you fit a g60 one?
Offline lemski
  • 16v
« Reply #7 on: 15 October 2016, 09:16 »
The brakes come on a little sooner. Better feel to the pedal.
Less pressure is needed to slow the car.
A must have upgrade especially when you put 288mm discs up front
Offline gazareth
« Reply #8 on: 15 October 2016, 20:06 »
I always thought that a wider bore master cylinder would make the pedal harder with less travel.
Offline lemski
  • 16v
« Reply #9 on: 16 October 2016, 07:58 »
Thats what ive just said. Brakes come on sooner...
My explanation may not have been the best. Haha
