Golf mk2
16V Missfire
Topic: 16V Missfire (Read 2623 times)
ewane_l
Just got here
MK2 16v
16V Missfire
03 October 2016, 09:02 »
Hi been having a bit of trouble with my 16v KR she developed a random misfire a few weeks ago. would drive fine start fine then all of a sudden start misfiring and cutting out i had a look at the leads and one of them the main coil lead was nackerd so i replaced the leads and put a new cap on this seamed to solve the problem but now its started again will be driving along perfectly fine then suddenly start misfiring it has now decided it wont idle which makes me think timing? also could it be the distributor its self ? any help would be greatly appreciated.
Last Edit: 03 October 2016, 09:33 by ewane_l
lemski
Forum addict
16v
Re: 16V Missfire
03 October 2016, 18:36 »
Hall sender on the dizzy or maybe the ign amp playing up, found above the ecu on the left hand side.
You can always time up the ignition but the advance isnt like the 8v so id have thought Hall sensor on the dizzy
ewane_l
Just got here
MK2 16v
Re: 16V Missfire
03 October 2016, 22:32 »
Great thanks i'll have a look at that in the morning .hopefully that will be it sorted
ewane_l
Just got here
MK2 16v
Re: 16V Missfire
08 October 2016, 06:52 »
so after a new dizzy and hall sensor she was running like a dream for about 20 miles then died again and wont start ;-( just ordered a new ignition amp but im starting to think its maybe fuel related
lemski
Forum addict
16v
Re: 16V Missfire
08 October 2016, 08:07 »
Fuel pump relay getting hot. When it cuts out is fuel pump still buzzing
ewane_l
Just got here
MK2 16v
Re: 16V Missfire
08 October 2016, 18:26 »
Ok great i'l check the relays see how that goes
Golf mk2
16V Missfire
