Author Topic: squeaking  (Read 4807 times)
Offline buddfridge
squeaking
« on: 13 September 2016, 19:32 »
There is a squeak or groan coming from the drivers side rear, I thought it was the back seats but if I gently rock the car back and forward it seems to be coming from the suspension, it's only a few months old and 2500 miles any ideas?  :sad:
gti pp manual white 5 door
Jackie Treehorn
Re: squeaking
« Reply #1 on: 13 September 2016, 20:38 »
Has it been very dry round your way?  Sometimes bushes dry out a little after a good shower and a drive it dissapears.
Offline clubsport
Re: squeaking
« Reply #2 on: 13 September 2016, 21:00 »
I had this, I searched online finding various threads and videos about shock absorbers etc..
It turned out to be the adjustable rubber stops on the rear tailgate.
I was surprised it was such a simple fix, it sounded far worse.
Offline Booth11
Re: squeaking
« Reply #3 on: 13 September 2016, 22:04 »
This is an R but did it sound like this?
https://youtu.be/IHQAJGrm7bU
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline buddfridge
Re: squeaking
« Reply #4 on: 14 September 2016, 06:40 »
Not as pronounced as that, at least not yet, but by using that rocking movement it does produce a squeak . As I am driving it sounds like a creak from the rear seat area...it may even be both.
It is in the garage so it's kept dryer than most..in response to the earlier post.
« Last Edit: 15 September 2016, 09:54 by buddfridge »
Offline Jan DR
Re: squeaking
« Reply #5 on: 14 September 2016, 07:26 »
are you sure it's not from the inside? I had once with a new Audi A4 a loose little spring inside the passenger seat that made a noise and it drove me crazy. I had to go 3 times to the dealer to get it solved
1st visit they told me it was imagination
2nd time they said it was the license plate and fixed that one
At the end I asked that a mecanic would join me for a test ride. he took place in the back and identified the noise
Golf 7 GTI TCR
Golf 6 GTI Cabrio
Offline buddfridge
Re: squeaking
« Reply #6 on: 14 September 2016, 09:52 »
I think its from behind the rear wheel.
Offline buddfridge
Re: squeaking
« Reply #7 on: 15 September 2016, 19:57 »
I got a bit closer to finding the cause...back seats are creaking from the drivers side only but it was dark so I will have to wait until daylight...anybody had this?
Offline buddfridge
Re: squeaking
« Reply #8 on: 18 September 2016, 19:06 »
An update as it might be useful, after checking the seats and finding nothing amiss I moved to the suspension on the drivers side, laying underneath I could see that the strut had a protective plastic collar fitted over the top part and it was not sealed.
I thought that it is possible with all my washing and the wet roads that some water might have penetrated the collar and done its worst on the suspension rod....so I decided to spray some wd 40 up the gap between the collar and strut, then the spring's just to make sure, I have gone for a good run out to check for the noise and thankfully it's gone, it was persistent and annoying so I am pretty sure its cured.
« Last Edit: 18 September 2016, 19:08 by buddfridge »
Offline p3asa
Re: squeaking
« Reply #9 on: 18 September 2016, 21:56 »
The problem with WD40 is it will just dry out and your problem will return.
