Author Topic: Fix or replace Golf G60 instument cluster  (Read 5588 times)
Offline Gnomyvw
« on: 22 August 2016, 13:39 »
Hi.
My instrument cluster has a burnt out copper track on the blue plastic circuit "sheet" on the back.
Does anyone know of a good place that could repair it or if I can use one from a different model?
Are the blue plastic circuit "sheets" the same between different models?
For reference the cluster part number is: 191 919 033 PG and it made by VDO.
Cheers.
1991 Golf GTI G60 "Edition Blue"
Offline lemski
  • 16v
Re: Fix or replace Golf G60 instument cluster
« Reply #1 on: 22 August 2016, 19:34 »
Should be the same through the 8v clocks. As long as the speedo and revs all match up.
Its probally easier to just get a set of clocks and swap the speedo out so it stays with the car
Offline Gnomyvw
« Reply #2 on: 23 August 2016, 08:20 »
Thanks Lemski. I was hoping the printed circuit sheet would be the same across some models. From what you say it looks like they could be.
Getting a set of clocks for the G60 is super hard - there are just 2 for sale on eBay.de atm - and one has a similar burnt out track as mine!
Offline jv
  • Administrator
« Reply #3 on: 23 August 2016, 10:23 »
Are they definitely not repairable? Is it because of how delicate they are?
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline lemski
  • 16v
« Reply #4 on: 23 August 2016, 11:01 »
Thats wjat I mean, get a set of gti clocks and swap your g60 speedo out to match your engine.
I mean its getting hard to find clocks that all work anyway, I had to take 2 sets to make 1 good set
Offline Gnomyvw
« Reply #5 on: 23 August 2016, 12:55 »
The 2 - 3 companies I spoke to wouldn't touch MK2 clusters now as spare parts are not available. The earliest models they work on are MK3's.
There was a company in Wales that would take a look a mine if I sent it to them but with no guarantee of repair - ball park figure I got from then was £150.
I'm gonna look out for a set of clocks and match up the circuit on the back to fix mine.
Offline jv
  • Administrator
« Reply #6 on: 23 August 2016, 14:43 »
Can you take a picture of the damaged board?
Buy site stuff!
Offline Gnomyvw
« Reply #7 on: 23 August 2016, 17:16 »
Sure - the burnt out track is the vertical copper wire surrounded by melted blue plastic (in case it wasn't obvious)  :laugh:
Offline oakgreener
« Reply #8 on: 23 August 2016, 22:26 »
I'm sure you could repair the damaged track(s)by bridging them with pieces of fusewire, soldered to a good bit of track. Scrape the insulation off.
The big question is though..........................WTF burnt it out.  :sad: Good luck
Offline lemski
  • 16v
« Reply #9 on: 24 August 2016, 19:25 »
Comes straight from a wire, have you checked the wire isnt also burnt out?
