Author Topic: Rear Brake disc outer corrosion  (Read 2836 times)
Offline Stuthebean
« on: 16 August 2016, 20:04 »
Has anyone else experienced corrosion on the rear brake discs? The Corrosion extends approximately 1-2 inches down from the top of the disc. I have the original pads and discs on the car, pads about 50% worn, discs look fine apart from outer corrosion. Car has done 50k, 5 years old. Looks like the pad is not evenly making contact with disc, it's the same on both. I will probably just change the pads and see if it clear up but it looks unusual.
« Last Edit: 16 August 2016, 20:16 by Stuthebean »
Offline RocketRossUK
Re: Rear Brake disc outer corrosion
« Reply #1 on: 16 August 2016, 22:28 »
It sounds like the piston is not pushing the pad out at right angle, you could just remove pads and clean and re-lube the caliper pins and see if that fixes the issue, but if its been like that for a while then the pads will more than likely not be straight
Offline Stuthebean
« Reply #2 on: 23 August 2016, 22:08 »
Cheers, I'll give it ago
Offline mwad gti
« Reply #3 on: 23 August 2016, 22:10 »
Yeah, I think RocketRoss is correct
2019 3 door manual GTi Performance in black
Bought 2 years ago as a 1 owner car, FVWSH and 10k miles
It’s a keeper
