Author Topic: New windscreen - any recalibration needed?  (Read 4939 times)
Offline Watts
« on: 05 August 2016, 14:41 »
I'm having my screen replaced next Tuesday (unless by chance it's repairable however very unlikely) and the booking email says I need to call them to discuss the need for recalibration of any cameras if I have ACC or emergency braking systems. I thought this was all in the sensor in the front bumper? I don't have lane assist so am I right and is there anything to be concerned about? Cheers :smiley:
Previously:
Offline Brenbo
Re: New windscreen - any recalibration needed?
« Reply #1 on: 05 August 2016, 16:56 »
The windscreen wiper sensor is on the windscreen.  Many years ago I had a windscreen replaced and the sensor never worked again.  But this was a long time ago, so hopefully windscreen fitters are more used to fitting windscreens with sensors and leaving the sensor in working order when they have finished.
As far as I know you are correct in thinking the sensor in the front grill handles ACC and emergency braking.
Offline Watts
« Reply #2 on: 05 August 2016, 17:10 »
Cheers Brenbo. Mind you the wiper sensor is stupid anyway :rolleyes:
Previously:
Offline GeoBog
« Reply #3 on: 05 August 2016, 17:26 »
Except the rain/light sensor which does not need recalibration, they might be referring to the Lane assist camera if you have this option however I highly doubt even that would require recalibration.
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline Watts
« Reply #4 on: 05 August 2016, 18:13 »
Thanks Geobog, looks like no need to contact Autoglass then. I really hope they can repair it though.
Previously:
Offline simonpolly
« Reply #5 on: 05 August 2016, 20:19 »
i had my windscreen replaced recently by autoglass on my touareg,i was a little worried about them replacing it so i guided the engineer towards a repair the repair wasn't 100 % successful because the chip had cracked but i paid the £10 excess anyway.I then had a change of mind and got back in contact with them ,they came back and replaced it free of charge under there warranty scheme (would have been £500 if i was paying) and ive got to say they were excellent.
The new screen comes with all the necessary bits to fasten the rain/lights sensor back to the new screen.
I would thoroughly recommend Autoglass their engineers were excellent.
« Last Edit: 05 August 2016, 20:22 by simonpolly »
Golfgti build quality is average at best.
Offline Watts
« Reply #6 on: 05 August 2016, 20:23 »
Thanks for that simonpolly, very reassuring.
Previously:
Offline davewilliams000
« Reply #7 on: 05 August 2016, 22:41 »
Agree... Auto glass were excellent when I had mine done recently too. Can't tell the difference except for the pilkington badge in the bottom corner instead of the vw one! :smiley:
2015 65 plate Mk7 GTD Manual in Tornado Red
   https://www.flickr.com/photos/davewilliams000
Offline itavaltalainen
« Reply #8 on: 06 August 2016, 10:20 »
They were good both times I had mine replaced too, though they cannot recalibrate sensors or camera.... which should really be done (camera in particular as it effects auto full beam quite dramatically).
Offline AntGTD
« Reply #9 on: 06 August 2016, 12:26 »
Had the windscreen replaced on my Golf after 4 weeks of owning it, requested a genuine VW windscreen and after 3-4 months i've not had an issue.
2016 Mk7 Golf GTD 180(ish) Reflex Silver with loads of stuff
