Author Topic: Weirdness on the way to work  (Read 4422 times)
Offline sKrEwBaLL
« on: 24 October 2003, 10:08 »
I was driving to work this morning and I was booting it in 3rd on a sliproad and then changed gear at about 6000 revs and then suddenly I heard this strange buzzing noise, it was loud and quite high pitched.  At first I thought it was coming from the engine, but it seemed to be coming from the dash, probably the clocks.  I slowed down a bit and tried to figure out what was going on.  It carried on for about 5 minutes and then someone phoned me and I explained to them that I thought my car was shafted, I said listen to the noise...  as soon as I said that it completely stopped!!
Any ideas as to what the noise couldve been....??  ???
Neil
Offline Gambit
Re:Weirdness on the way to work
« Reply #1 on: 24 October 2003, 10:11 »
oil pressure warning
Offline sKrEwBaLL
« Reply #2 on: 24 October 2003, 10:12 »
The light didnt come on though  ???
Offline Gambit
« Reply #3 on: 24 October 2003, 10:25 »
aye the light comes on for low oil pressure and the buzzer for high oil pressure
or vice versa, i can never remember!!
Offline sKrEwBaLL
« Reply #4 on: 24 October 2003, 10:26 »
What does it mean if Ive got high pressure..?
Offline m4nesh
« Reply #5 on: 24 October 2003, 10:32 »
the pressure of the oil is high!   :P
Offline sKrEwBaLL
« Reply #6 on: 24 October 2003, 10:35 »
No sh!t sherlock
Offline Gambit
« Reply #7 on: 24 October 2003, 11:06 »
its not high pressure, its a lack of pressure at high rpm's (i think!)
could be caused by a bit of dirt getting sucked into the oil lift pump in the sump which is enough to reduce the oil flow when the car is under load
Offline AdamB
  • The Perfect Storm
« Reply #8 on: 24 October 2003, 11:13 »
I had this same problem on my cab. It used to happen at the same point every journey, so I put it down to interference, on the radio,  from a RADAR on the airfield next to the road - however it happened on another road one day, and I pinned it down to my speedo - it used to make the high pitch whine at 62mph+. I took the speedo out, and cleaned the coupling between the enertia disc and its housing, put it back together and it has never happened since. I reckon it could have been a bit of grit or dirt causing it to vibrate at higher revolutions.
I don't own this anymore - I just can't be arsed to change the picture
Offline sKrEwBaLL
« Reply #9 on: 24 October 2003, 11:25 »
The only thing that worries me is that I was red-lining it just as it happened  :(
