Author Topic: No Spark  (Read 2699 times)
Offline Grant_GTIT
No Spark
« on: 03 June 2016, 17:39 »
My 1.8T AGU cut out on me and now wont fire back up, it turns over.. I can hear the fuel pump prime. Up to yet I have I have tried a different crank position sensor, cam sensor, ignition amp and replaced spark plugs. I have checked all fuses by the drivers door and on top of the battery. I have had it scanned but not with vag com, with only boost pressure valve the only code to appear. Anyone shed any light on this for me? TIA
Offline lemski
  • 16v
Re: No Spark
« Reply #1 on: 03 June 2016, 17:42 »
Ide say crank sensor as its just turning.  Also everytime ive done a crank sensor there never a code stored
Offline Grant_GTIT
Re: No Spark
« Reply #2 on: 03 June 2016, 18:05 »
I had a brand new genuine one last year, but trued with another to eliminate the CPS, the rev counter moves a little as im cranking which also suggests the CPS is good. I'm getting fuel but no spark :/
Offline lemski
  • 16v
Re: No Spark
« Reply #3 on: 03 June 2016, 21:47 »
Its unusual for 4 coilpacks, id move to ign amp but you say youve swapped it for another?
Offline Grant_GTIT
Re: No Spark
« Reply #4 on: 03 June 2016, 21:51 »
I have tried another yh, but it was from a breakers and wasnt exactly the same as mine, as though it was an aftermarket IA, would a faulty IA cause no spark to all 4 coils, if so then i'll look to find another part to try
Offline lemski
  • 16v
Re: No Spark
« Reply #5 on: 04 June 2016, 10:24 »
They normally only drop one spark first. But its possible to drop all of it.
Ecu hasnt imobilised its self. I dont know if its fuel or spark they do.
Mate had an s3 where his ecu imobilised. Just deimobilised ecu. If you scan instrument cluster itll say a fauly is there if it has
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: No Spark
« Reply #6 on: 04 June 2016, 22:09 »
Try the fuse that feeds the coils... can't remember the exact one but it's 20amp
