Author Topic: Looking to buy a GTI in the near future  (Read 3850 times)
Offline uk345
« on: 30 March 2016, 22:39 »
Very interested in buying a GTI in the near future and wanted to ask a couple of questions. I love these cars and they tick all the boxes for me but one thing that is scaring me is the camchain tensioner failing. It seems like a relatively common issue and having read through the thread regarding this i am a tad considered. Did VW improve the design on the later MK6 models ? If so from what year ? Any other issues i should look out for ? I want a manual, full leather seats, sat nav and the bigger alloy wheels
Thanks
Offline The ANT
Re: Looking to buy a GTI in the near future
« Reply #1 on: 30 March 2016, 23:45 »
They did sort the problem, I can't remember when, if you buy an early one like I did make sure it has been sorted either with a new tensioner or engine. Mine had a new engine in 2013 (before I got it).  If there's no evidence of this, call the dealer/garages which have done the servicing, or you could be in for a lot of hassle, even though vw should give you an engine.
Suffering from a severe and unforgiving case of GTItis
Offline seabrook132
« Reply #2 on: 31 March 2016, 11:22 »
Everything you need to know about the chain tensioner is in the thread: http://www.golfgtiforum.co.uk/index.php?topic=262793.0
There was a revised tensioner introduced in May 2010. It was then revised again in December 2011 and May 2012. All failures bar one that I know of have been on 2009-2010 cars, so if you're budget allows then looking for a 2011 onwards car would be preferable (you also get the cool LED rear lights as a bonus). There is one 2011 car that had the timing chain let go at 115,000 miles but I would put this down to timing chain stretch rather than the tensioner and was probably preventable had the engine been listened too. My GTI is a 2011 car and has been perfect up to 75,000 miles. I am planning on getting the chain and tensioner changed at 80,000 and treating it as a cambelt change. Prevention is cheaper than cure! So if you get an early car, either make sure the latest tensioner has been fitted or get it done when you get the car.
As far as other issues go, water pumps can fail and leak so have a check for any leaks under cars you view. To be honest I've heard more about this on US forums rather than on here though so not sure whether it's LHD or country specific.
You say you want the larger alloys, I assume you mean the 18" Monzas? These are diamond cut and thus are very susceptible to damage and corrosion. My car had all four wheels refurbished just after I bought it and they have been lovingly cared for ever since, sealed every 6 months and never kerbed, but the whiteworm corrosion is returning on a couple of them, probably due to stones chipping the lacquer unseen. They look great but are fragile in terms of appearance like any diamond cut finish. I paid £390 for the refurb just as a guide.
The turbo wastegate can rattle on acceleration or deceleration so do part of your test drive with the window open and listen for this. Not a big issue this, VW issued a technical instruction about it and there is a very cheap clip that solves the issue.
I'd say don't be put off by the chain tensioner issue at all. They really are fantastic cars, I've put 40,000 miles on mine in the 2 years I've had it, mainly because I can't stop driving it because I enjoy it so much. None of that is commuting mileage  :laugh: . Also I know the sat nav (RNS-510) looks cool but I wouldn't count out cars that have the touchscreen but no nav (RCD-510). You still get the same screen, just with 3 buttons down each side rather than four, and tbh the sat nav is dated now.
Let us know how you get on with your search!
2011 GTI DSG 5dr, Tornado Red, 18" Monza Shadows, Heated Leather, RNS-510, MDI, Bilstein B16 PSS10 Coilovers, Ohlins DCC Cancellation Kit, Audi TT-RS Front Top Mounts, Whiteline 24mm Rear ARB, Michelin Pilot Sport 4, 034 Motorsports Street Density Engine and Gearbox Mounts, Audi R8 Red Coil Packs, NGK BKR7EIX, Millers 5W-40 Nanodrive
Offline chris1h
  • MK6 GTI BLACK 3 DOOR
« Reply #3 on: 31 March 2016, 20:33 »
Thanks
Hi buddy,  please take a look in the classfieds. link below should work. Mine is up for sale. ticks all your boxes  :nerd: :whistle:
http://www.golfgtiforum.co.uk/index.php?topic=277260.0
MK6 GTI - 2011 - PEARL BLACK - 3 DOOR  - 18" MONZA SHADOWS  -  RNS510/DAB  -  ACC  - SUNROOF  -  WINTER PACK  - DYNAUDIO  -  VIENNA LEATHER  - PARKING SENSORS  - BLUETOOTH
Offline The ANT
« Reply #4 on: 31 March 2016, 21:04 »
With the 18" monza wheels, diamond cut wheels aren't really up to the British climate. Mine have been refurbished  with black and silver paint instead of being black then cutting the face. You wouldn't notice unless you look close or had some diamond cut wheels next to them. I'd recommend that with our weather. I had a 14" bbs wheel off a mk2 diamond cut in February, that cost me 90 quid.
Offline chris1h
« Reply #5 on: 31 March 2016, 21:12 »
just need keep the dirt off them! mine have zero white worm but washed once a week so salt and muck doesnt build up!  i agree out climate is rubbish and a good set of winter wheels would reduce white worm even more! :smiley:
