Author Topic: Clutch not returning  (Read 6331 times)
Offline Waspy
Re: Clutch not returning
« Reply #10 on: 25 March 2016, 14:27 »
I didn't use an alognment tool, just managed to get it right by luck I guess haha.
I'm just going to do them all again (full linkage). It's an easy job, overkill maybe, but I'm not bothered
Offline oakgreener
« Reply #11 on: 25 March 2016, 16:41 »
Got the car back today and it drives fine. Bite point is much lower obviously, which is nice.
What was wrong with the clutch then?
Offline Waspy
« Reply #12 on: 25 March 2016, 16:47 »
Neither me, nor the garage know what was wrong.
It was like the rod was too short (didn't look badly worn), so they added a spacer (half an old release bearing) to effectively extend it. Like I say, it doesn't sit well with me, but it seems to drive well, other than sloppy gear linkages.
Offline gazareth
« Reply #13 on: 02 April 2016, 14:37 »
the small clutch levers that go against the release bearing have a habit of cracking which makes the pedal not return. but in saying that,when they crack they don't normally work again even with a spacer fitted. I know someone who had the same issue a couple of years back. to fix it they took out the push rod, cut it in half and put a small ball bearing in between the 2 halfs :huh:
