Author Topic: Clutch not returning  (Read 6338 times)
Offline Waspy
« on: 18 March 2016, 16:18 »
Long time guys, hope you and your mk2s are all well!
Had the clutch replaced today at a local garage I trust. They just called to say it's done but they have a problem with the clutch peddle not returning. They have asked me to come and look at it tomorrow.
Is this a common issue after a new clutch? Is there something I should be looking for? Advice appreciated as always
Offline sparkplug
Re: Clutch not returning
« Reply #1 on: 18 March 2016, 18:10 »
does it have an auto adjust cable ?
as they can bind up similar to MK3  ....https://www.youtube.com/watch?v=iiyox3Px5GQ
or maybe this ....https://www.youtube.com/watch?v=jCyMFfRPZJM
good luck  :smiley:
« Last Edit: 18 March 2016, 18:15 by sparkplug »
1986 GTI atlas grey
Offline Brighouse-gti
« Reply #2 on: 18 March 2016, 19:51 »
Did they put the clutch assembly back together the right way? It goes in backwards!
Offline Waspy
« Reply #3 on: 18 March 2016, 21:33 »
I have no idea if they put it in the right way or not...
How will I tell? And more to the point, can I prove it?! Don't want to pay another 4 hours labour to find out...
And it's a manual cable changed a year ago
Offline Waspy
« Reply #4 on: 19 March 2016, 09:29 »
Okay so he showed me everything today. He also showed me the old clutch on the bench, looks like it would be very hard to fit backwards! No impossible, but hard.
The problem is that the clutch lever is too far from the release bearing. So it's trying to push it, but can't if you see what I mean. They are gunna put a spacer inbetween the lever and bearing to make it drive. But I'm not happy at all!
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #5 on: 19 March 2016, 12:21 »
You really can't get anymore straight forward than fitting a clutch to a Mk2! its either the wrong kit, or they have fitted it wrong, get them to sort it properly!
Thom
Offline Waspy
« Reply #6 on: 19 March 2016, 12:53 »
Thom
I only sent it to a garage because I don't have time atm to be working on the car. I provided the clutch unfortunately (had it lying round so thought I would save the parts cost) but that gives the garage an out. They are just blaming the clutch, which I am almost certain is the correct one. It's a Sachs. I'll get it back and find/make time to sort it out myself.
I need to find a decent VW specialist locally for future stuff.
Offline Waspy
« Reply #7 on: 22 March 2016, 14:23 »
Got the car back today and it drives fine. Bite point is much lower obviously, which is nice.
However, the shift throw is now WAY longer. As in the distance the gear lever travels from 1-2 etc. I'm confused why this has changed. Purely as an FYI I did all the linkages 2 years ago.
Just doesn't seem as tight now...
Offline lemski
  • 16v
« Reply #8 on: 22 March 2016, 16:16 »
Make sure the 13mm nut is tight on the linkage. Mine wasnt and the throw was horrible. Eventually lost gears. Tightened it and jobs a goodun now
« Reply #9 on: 25 March 2016, 13:55 »
Yeah when I said it goes on backwards, I ment as in it re-assembles backwards. Normally (on most cars) the flywheel goes on first (closest to engine) and the clutch assembly goes on after. On the olde golf its the clutch assembly that goes closest to the engine and the flywheel bolts to the clutch. However if that problem is somewhat cured then no sleepless night!
If you did your linkages yourself 2 year since did you use the alignment tool? Have you still got it? Could you not just do the alignment again, yourself?
