Author Topic: Temperature warning light on start up  (Read 6020 times)
Offline itavaltalainen
Re: Temperature warning light on start up
« Reply #10 on: 22 February 2016, 16:09 »
Try cleaning the electrodes in the expansion tank.
No faults does not mean nothing is wrong - OBD2 dongles are rubbish at properly diagnosing faults.
Offline eug2huge
« Reply #11 on: 22 February 2016, 16:43 »
Yeah, I though as much.
Will give it a clean at the weekend.
Offline AntGTD
« Reply #12 on: 22 February 2016, 19:58 »
Had this on several MK5s - replaced the expansion tank and the alarm was no more. Its about £25 and takes 10-15 minutes but must be done when the coolant is stone cold.
2016 Mk7 Golf GTD 180(ish) Reflex Silver with loads of stuff
Offline ub7rm
« Reply #13 on: 25 February 2016, 23:33 »
Golfs (and other VAG's) have been doing this since at least the mk4 era - fix is to ignore or replace the coolant tank cw sensor.
2020 BMW 128ti
2017 Golf GTD Estate
Offline eug2huge
« Reply #14 on: 26 February 2016, 12:33 »
Many thanks. Don't suppose anyone has the MK6 part number please?
Offline seabrook132
« Reply #15 on: 26 February 2016, 17:14 »
Here you go mate, not entirely sure how the pricing works (whats that +18% all about?) but here's the number:
2011 GTI DSG 5dr, Tornado Red, 18" Monza Shadows, Heated Leather, RNS-510, MDI, Bilstein B16 PSS10 Coilovers, Ohlins DCC Cancellation Kit, Audi TT-RS Front Top Mounts, Whiteline 24mm Rear ARB, Michelin Pilot Sport 4, 034 Motorsports Street Density Engine and Gearbox Mounts, Audi R8 Red Coil Packs, NGK BKR7EIX, Millers 5W-40 Nanodrive
Offline mike.
« Reply #16 on: 27 February 2016, 09:15 »
The 18% is just the country's VAT rate.
You need to go to "maintenance/settings" and change the options under country Settings, like below.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline seabrook132
« Reply #17 on: 27 February 2016, 09:48 »
Awesome, thanks for your help mate!
Offline eug2huge
« Reply #18 on: 04 March 2016, 14:40 »
Replaced the tank at lunch. Guess I'll know if it's solved the problem tomorrow morning when it cold!
Of course I dropped one of the screws down a plastic channel..
don't drop the screw, don't drop the screw, doh!!
Will have to fish it out with a magnetic pickup later.
