Author Topic: Temperature warning light on start up  (Read 6034 times)
Offline eug2huge
« on: 19 February 2016, 09:47 »
Hi guys,
A few times this winter when I start my gti up in the morning the temperature warning light come on and there is an audible beep!
Seems to only happen when it's below freezing. I have checked the coolant level (which is fine) and made sure the cap is tightened correctly.
If I re-start the car the light goes out. When I continuing to drive the temperature reaches the normal level and there are no further issues.
I am guessing this is a sensor issue? Has anyone had this? I have a diagnostics dongle and have checked for errors but none come up.
Very queer...  :smiley:
Offline Rgdogg
Re: Temperature warning light on start up
« Reply #1 on: 19 February 2016, 10:20 »
It does it on my golf, I think it's when the temp is 4 degrees or below, just to let you know that road and weather conditions may be slippy.
Gti, Candy White, 3door, DSG, Leather, Rear LEDs, Bluefin, Milltek, vwr intake, Focal speakers.
Offline eug2huge
« Reply #2 on: 19 February 2016, 10:43 »
Thanks, does yours go out if you continue? mine doesn't which seems disconcerting..
Offline jv
  • Administrator
« Reply #3 on: 19 February 2016, 11:13 »
Must still be cold outside then  :tongue:
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline eug2huge
« Reply #4 on: 19 February 2016, 11:17 »
Had the car for over 3 years and has only started this winter..
Still finding it a little queer...  :undecided:
Offline SunnyGTI
« Reply #5 on: 19 February 2016, 11:25 »
I have had it only come on recently, but I think that is because the guy with VCDS/Vagcom turned on this temp for me..!
Offline gaurav_aidasani
« Reply #6 on: 20 February 2016, 20:20 »
On my car everytine the outside temperature drops below 4 degrees it gives a beep. Just a warning that the roads might be icy, nothing more.
Offline joe6
« Reply #7 on: 21 February 2016, 17:44 »
Mine gives a beep below 4 degrees and the temp in the MFD flashes for a few seconds.
Offline itavaltalainen
« Reply #8 on: 21 February 2016, 20:40 »
Which temperature warning light are you talking about?
Red coolant temperature light or the snow flake symbol?
If you have VCDS then check measuring blocks and see if outside temperature, all coolant temperatures etc are all plausible.
Offline eug2huge
« Reply #9 on: 22 February 2016, 12:44 »
It's the red light that comes on and stays on (only when freezing or below).
Don't have VCDS unfortunately but have checked with my dongle/app. No errors showing..
