Author Topic: think mechanic broke my car? (suspension install nightmare)  (Read 2884 times)
Offline Dipesh2031
  • Options bae?
So,
Booked the car in to install VWR springs, went with these because of the ACC suspension.
The garage has a good rep because their head mechanic is top notch, I made the mistake of letting the others work on the car,
but when they were doing the springs (which is a simple enough job) they didn't take off the drive shaft bolts and just kept them in, also without using a hub spline tool they just banged off the hubs with a hammer... now on normal shocks this wouldn't concern me, but on electronic shocks with all sorts of tiny parts? maybe I'm just being paranoid, but the ball joints on both sides looked stretched to their max articulation same with the drift shafts as they pushed the hub off the strut (whilst the strut was still in, these angles to me looked very alarming, I couldn't really see what was going on until this was already done and there wasn't really any turning back...
Guess my question is, are my ball joints okay? are my drive shafts okay? what kind of damage can happen if they are bent down too much because they were bent down quite far to get the hub off the strut.
Oh and to top it all off? they broke my AFS level sensor for the headlights so xenons point to the floor, and ACC suspension is off so it feels like I'm on coilovers. (local plastic welder to the rescue)
I hope they trip and break a leg. only paid £80, but shocking non the less. not sure weather to go out and buy new ball joints and other parts... it's not like DSG drive shafts are cheap!  :cry: :cry: :cry:
any advice greatly appreciated!
Thanks
MK6 GTi - Black - DSG - 18' Monza shadow - Luxury Pack - Convenience pack - Park assist - Xenons - RNS510 - Adaptive chassis control - Dynaudio - Bluetooth - Reverse camera - front/rear sensors --mods-- Evoms Intake - Eurojet/stasis Turboback Catless 3" exhaust
Offline SunnyGTI
Re: think mechanic broke my car? (suspension install nightmare)
« Reply #1 on: 29 January 2016, 15:35 »
Oh no...if you think something is not right I would go back to the garage, even if it was cheap job. They should still do it right..!
Offline Pinky1959
« Reply #2 on: 29 January 2016, 15:46 »
Get another garage to check it for you , it may cost but at least you will know for sure , and if it is damaged you can tell the other garage to sort it properly.
Offline Dipesh2031
  • Options bae?
« Reply #3 on: 03 February 2016, 17:28 »
they fixed the sensor, the car drives alright, the VWR springs ride stiff, but the car feels very planted and controlled, more so than before!
im sure any damage to drive shafts will show soon, but mechanics say you cant really tell if they've been damaged. and that drive shafts can take a bit of a battering?
