Author Topic: mill light  (Read 2913 times)
Offline yougy
mill light
« on: 20 December 2015, 10:54 »
iv a 2003 golf mk4 gti turbo 180bhp, it sat for 2 weeks on drive, when I took it out yesterday I had the mill light come on also the light above with the triangle, scanned it and this came up
01435 brake pressure sensor
01314 soft ware
16486 maf signal
16955 soft ware
any ideas that can help me
thanks dave
thats fooked it
Offline bgbazz
  • If it aint broke...I can fix it!
Re: mill light
« Reply #1 on: 20 December 2015, 14:20 »
Is the battery fully charged?
If you reckon it is, you might try this trick as a long shot...disconnect the battery for half an hour or so, then hook it back up and see what happens. You could have a charger hooked up to the battery while it's disconnected, just to give it some more zap.
Might be a good idea to have your radio security code handy...just in case.
Not sure this method will work with a VW, but I've used it on lots of other makes and it has worked a treat.
And all it will cost you is a bit of time!
Mk4 Golf TDI Estate 4Motion, remapped 1.9. Sweet runner = keeper. She is the 66th vehicle I've owned and hopefully, the last.
Offline yougy
Re: mill light
« Reply #2 on: 20 December 2015, 14:30 »
battery is fully charged, drove around yesterday and today in it, I disconnected battery for about 20mins but errors came back, I disconnected maf drove around today and car seems to drive a lot better, so im guessing the maf is fooooked. going to try and borrow one tomorrow to test it
thanks dave
thats fooked it
Offline barrym381
Re: mill light
« Reply #3 on: 20 December 2015, 14:41 »
sounds like your maf tbh but best trying a working 1 if you can before buying a new 1 :smiley:
Offline bgbazz
Re: mill light
« Reply #4 on: 20 December 2015, 16:26 »
At least you have the problem isolated now..tbh I never considered the maf as in all the diesels I've owned, only one (Pug 406) had it go sour and then it used to throw me into limp mode.
Offline yougy
Re: mill light
« Reply #5 on: 22 December 2015, 17:58 »
all sorted new maf
cheers peeps
thats fooked it
