Author Topic: touran 2.0 tdi sport gearbox/clutch  (Read 3784 times)
Offline ginga
« on: 02 December 2015, 17:52 »
hey
I have an issue with my touran, I'm struggling to find 1st 2nd and reverse. not every time its doing this but when it does I have to select other gears before I can continue with setting off. any ideas please
Offline itavaltalainen
Re: touran 2.0 tdi sport gearbox/clutch
« Reply #1 on: 02 December 2015, 18:31 »
Could be clutch related, worst case DMFW.
Offline ginga
« Reply #2 on: 02 December 2015, 18:36 »
Dmfw?
Offline Rhyso
« Reply #3 on: 02 December 2015, 19:05 »
Dual mass flywheel
Offline ginga
« Reply #4 on: 02 December 2015, 21:05 »
B e a utiful
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 03 December 2015, 15:39 »
Sounds more like an input shaft bearing issue to me, really common on the 6 spd boxes. There are 2 options to repair, first involves fitting a shim from the outside which we've had limited success with. The more permanent solution involves removing the gearbox and replacing the failed parts which is obviously going to be more expensive.
Offline ginga
« Reply #6 on: 03 December 2015, 16:16 »
So if it's the bearing issue would it be cheaper to fit a new box?
Offline ginga
« Reply #7 on: 03 December 2015, 20:08 »
Just been looking online about this bearing and most people say that they have a whirring noise. I have no noises just annoyance at traffic lights and junctions
