Author Topic: Cam Belt Change Problem - Need Help Please  (Read 2989 times)
Offline Rickkap
« on: 21 November 2015, 20:47 »
Hi all
 Please excuse me if this is the wrong place for asking for help...
 The car in question is - Golf MK6 2.0 TDI CBEA 2009
 I am relatively new to this forum and I don't normally do repairs or replacement to my car but after getting a quote from VW for changing my cam belt I and a very experienced good friend of mine decided to do it ourselves. My friend has over 18 years experience in stripping and rebuilding engines so I knew we would be ok in doing this.
 I purchased the Hynes manual explaining all the steps and we started to follows this. The problem we have is after changing the belt, water pump, fuel filter, oil filter, oil etc is the car won't start. It will turn over but not firing.
 At first there was a starvation of fuel from the HPFP to the engine which after removing the pipes to the engine and using vcds to force both fuel pumps on we started to get fuel. But this didn't fix the problem.
 I then started to search the net and one thing I've found, which the Hynes manual didn't mention, was that the camshaft 'crown' needed to be at the top with the crankshaft at TDC and not at the bottom which ours was.
 In the picture below you can see that we locked the crankshaft at TDC but the camshaft is at 180 degrees out and the locking pin isn't fully inserted.
http://www.imac-repairs.co.uk/temp/1.jpg
 When we removed the belt nothing moved apart from the camshaft sprocket slightly because the nuts where loosened.
 As the major problem here is that we didn't set the camshaft at the correct position and the car isn't firing over, how can I resolve this problem?
 Can I put the crankshaft back at TDC, lock it in position and have the camshaft crown as close to the top as possible and then manually, without the belt attached, move the cam shaft so that the crown is at the top!!!
 Any help would be very much appreciated.
Offline golfhappy
Re: Cam Belt Change Problem - Need Help Please
« Reply #1 on: 22 November 2015, 10:38 »
Well first of all what did you do to the car which wouldn't make it fire? oil filter...no water pump...no fuel filter...probably..is there fuel getting beyond the filter to the injectors? can you remove an injector and try it. pop it into a plastic bottle to see, don't blame me seen Ed China do this  :smiley: as for the timing belt replacement a, no expert only done these on Ford CVH engine...but if you lock it in any position as long as it doesn't move it should be ok. Good luck
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline gazareth
« Reply #2 on: 22 November 2015, 18:15 »
why would you loosen the camshaft sprocket bolts? btw Haynes manuals these days do nothing other than balancing wobbly coffee tables.
« Last Edit: 22 November 2015, 18:18 by gazareth »
Offline ajmoir36
« Reply #3 on: 03 December 2015, 17:25 »
Did you put the fuel hoses back the wrong way round?
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline Gaz-M
« Reply #4 on: 10 December 2015, 15:57 »
Im not being funny, but your 'very experienced' helper, doesnt sound very experienced if he cant do a belt on a very common engine!
Double check anything stupid like advised above, otherwise take it to someone who actually knows what theyre doing.
You shouldnt need to even think about where the camshaft lobes are.
