Golf mk3
hardmonkeys
Please please help alternator
4
Topic: Please please help alternator (Read 8562 times)
Andy grim
18 October 2015, 20:46 »
Can anyone help put a new battery on the golf but it keeps
Going flat also my interior lights are flickering but when I rev it it stops could the alternator be at fault please help
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: Please please help alternator
18 October 2015, 21:55 »
Yeah, probably the voltage regulator is gone (or its counterpart, maybe diodes). My money would be on reg though.
Andy grim
18 October 2015, 21:57 »
Ok is it a easy job to replace the alternator it's a 1.8 se cheers
itavaltalainen
18 October 2015, 22:15 »
5 minute job
Andy grim
18 October 2015, 22:16 »
Really not for me lol
itavaltalainen
18 October 2015, 22:18 »
Loosen both bolts, push alternator down and keep down, slide belt off.... allow alternator to come back up. Take both bolts out, off it comes. Fitting new one is reversal of above. 5 minutes easy.
Andy grim
Reply #6 on:
18 October 2015, 22:22 »
Ok will give it a go when the ignition is on the lights don't flickerer but the minute the car is running they flicker but when I rev it it stops thanks for your advice mate appreciate it
itavaltalainen
Reply #7 on:
18 October 2015, 22:33 »
Oh btw... I only mentioned mechanical connection. There is a connector to regulator that needs to be pulled off and one cable to battery also needs undoing (very good idea to disconnect battery first!!).
Andy grim
Reply #8 on:
18 October 2015, 22:34 »
Ok is the regulator and the alternator one unit
itavaltalainen
Reply #9 on:
18 October 2015, 22:54 »
Yep, regulator is a part of alternator, it can be replaced rather than whole alternator but you need to have an eye to check alternator itself has not been damaged by worn carbon brushes.
I put a guide together on how to change them, it's in German but pictures should be enough.
http://www.motor-talk.de/forum/aktion/Attachment.html?attachmentId=716521
4
Golf mk3
hardmonkeys
