Author Topic: Please please help alternator  (Read 8535 times)
Offline Andy grim
Re: Please please help alternator
« Reply #10 on: 18 October 2015, 23:16 »
Thanks but seen a bosch one on ebay so will probably get that thanks for all your advice  :smiley:
Offline Andy grim
« Reply #11 on: 19 October 2015, 16:47 »
I tested the alternator today and with things on I got a reading of about 12.7 to 13 volts is that good was going up and down wasn't really steady
Offline itavaltalainen
« Reply #12 on: 19 October 2015, 16:51 »
I assume this was with engine running but nothing else on (lights, rear window heating etc)?
If all these things are off you should be getting about 14V. 12.7V to 13V and fluctuating means something around alternator is faulty (unless your battery is completely cooked - but then you'd have massive issues starting it up).
Offline Andy grim
« Reply #13 on: 19 October 2015, 17:19 »
No that is with everything on with the lights flickering could it be a bad earth?
Offline Bandit127
« Reply #14 on: 19 October 2015, 17:22 »
Where did you measure the voltage? If it was anywhere other than the battery terminals (like the cigarette lighter socket) then you should measure again. Internal voltages seem to be more regulated than the charging voltage. Or perhaps there is a voltage drop on the supplies to car internal power.
I never saw more than 13.4V on my Mk3 at the battery terminals but the battery never got flat in over 10,000 miles.
Offline Andy grim
« Reply #15 on: 19 October 2015, 17:23 »
No mate directly to the battery
« Reply #16 on: 19 October 2015, 19:14 »
I used to measure away from battery as it is a massive sink hole for electricity....
Offline Andy grim
« Reply #17 on: 19 October 2015, 20:27 »
I am going to do the alternator because it sounds easy to do but I think maybe the lights flickering is a each somewhere that's not too good where's a good place to start earth wise
Offline gazareth
« Reply #18 on: 20 October 2015, 19:49 »
if your engine fired up easily when the new battery was fitted then it is unlikely a problem with the main earth wire. not sure if the battery to bodywork wire being faulty would cause the flickering lights though? try measuring the charging volts directly of the alternator (thick wire from battery). if the reading goes up to 13.5-14.5 then the wire is faulty somewhere. if reading is the same then the alternator is probably goosed.
Offline Andy grim
« Reply #19 on: 20 October 2015, 19:58 »
So the alternator could cause the flickering lights have any one else had the same issue also I am keeping a eye on the battery drain two days ago it was on 12.37 v have not started it in two days checked it today and it's on 12.18v is the about right or two much drain cheers also have a 063 battery is it two small looks tiny for a 1.8 petrol thanks
« Last Edit: 20 October 2015, 20:02 by Andy grim »
