Author Topic: Taken the wrappings off - what next ?  (Read 6641 times)
Offline TwoSheds
« on: 13 October 2015, 14:42 »
Picked up my GTD & removed the protective wrappings, labels etc myself.
Gently hosed off the leaves and crud on returning home.
Before I rush into things will solvents like Tardis remove both iron contaminants and any remaining adhesive ?
If so do I need to hose the car with water i.e. wet it first, before applying Tardis by hand spray panel by panel ?
Any advice on the sequence or the best way to do it such as use microfibre cloths ?
I don't want to damage the paint surface before I even get to the stage of applying polish and sealants.
Many thanks for any advice ...
« Last Edit: 13 October 2015, 14:45 by TwoSheds »
Offline Booth11
Re: Taken the wrappings off - what next ?
« Reply #1 on: 13 October 2015, 15:14 »
Hi TwoSheds.
I’ve just done mine this last weekend just gone and someone asked the same question which is in the ‘what have you done’ thread but here’s the procedure I used:
Important to start off with a good wash to get any grit, dirt off otherwise you'll just be rubbing that into the paintwork when you apply the Tardis or Iron remover.  So a thorough wash.  I snow foamed and then 2 bucket wash, rinse and dry.
Then I moved onto the decontamination phase, starting with the Iron X first. However it doesn’t really make much difference if you do it the other way round starting with tar remover first.
I started with the roof first, then one side of the car, including the wheels, then the other side, the rear and front.  You could do it a panel at a time but I find a few at once if fine.  I sprayed it on, let it dwell for 5 mins (less time if it's sunny), gave it a gentle rub over with a very soft Micro Fibre and then rinsed off thoroughly and dried it off as the next step - tar remover needs to be applied to a dry surface.  Then onto the Tardis.
Similar procedure, applied to a dry car, either sprayed on directly or applied with a very soft Micro Fibre cloth a panel or two at a time, then wiped over gently with a MF, and rinsed off thoroughly. Don't let the solvent dry on the car, I wiped over almost immediately and concentrated efforts on the areas where I knew there was glue residue from the stickers.  The residue melted off easily so there wasn’t the need to ‘scrub’ away at it, just apply a little extra Tardis to the areas where the glue is evident and wipe over gently until it has dissolved away.  No abrasive action was required at all.  Then rinse off very thoroughly.
Finally wash the car, rinse and dry.  Or if you are claying you don’t need to dry it off just move onto that step.
Hope this helps.  :smiley:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Booth11
« Reply #2 on: 13 October 2015, 15:22 »
Just one other thing.
Tar remover, such as Tardis, will only remove glue and tar contaminants.  To remove iron deposits and 'fallout' you need iron remover, such as CarPro Iron X or similar. It's a 2 stage process, or 3 if you decide to clay any remaning contaminants afterwards.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline TwoSheds
« Reply #3 on: 13 October 2015, 15:38 »
Hi Booth.
Funny I was just googling Iron X as you mentioned it in your reply.
Thank you very much for all that info its just what I needed to get started the right way.
The car is pretty grubby at the moment so will be getting its first proper wash this weekend prior to the start of 'decontamination'
Offline Booth11
« Reply #4 on: 13 October 2015, 21:31 »
Hi Booth.
Iron X is good stuff.  There's a lemon scented version.  Don't bother, it smells no better than the sulphurous normal version.  Someone else on here told me that, but I tried it anyway, but there were right, it still stinks.  :sick:
Good luck with the decontamination. Let us know how you get on with it.It's actually one of my favourite stages of the detail.
Btw, any MF's you use for the Tardis should be chucked straight in the bin afterwards. Probably best to do same with your Iron X cloth too.  And do not wash your detailing clothes with anything else, otherwise your washing machine and other clothes will stink for ages, and your Mrs/girlfriend will not be best pleased.  :laugh:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline TwoSheds
« Reply #5 on: 14 October 2015, 08:40 »
Thanks for the heads up on the Iron X.
I noticed there is a lemon scented version which I would have ordered in preference thinking thats a good idea.
Yes I will be dumping the MFs after use.
Hadn't thought about the washing clothes bit and would certainly have been in the doghouse with my Mrs over that - good tip
Offline KyleB
« Reply #6 on: 14 October 2015, 12:25 »
Another heads up...they both stink to high heaven.
Offline Booth11
« Reply #7 on: 14 October 2015, 13:17 »
I'm sure it was you Kyle that told me that but I opted for the Lemon one anyway and you were right. Equally stinky stuff :laugh:
Although I think you get used to it, it doesn't bother me now, and as for Tardis.......Mmmm :drool: Could sniff that all day long!  :grin:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline KyleB
« Reply #8 on: 16 October 2015, 14:51 »
Yeah it was. I got the Mrs. the other day to smell Bouncers Done and Dusted and then said to her, take a deep breath of this (Iron X), you can imagine her reaction!  :evil:
Offline Booth11
« Reply #9 on: 16 October 2015, 15:28 »
 :grin:
You evil man!  She might like Tardis.  :whistle: :laugh:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
