Author Topic: Footwell lights - How many?  (Read 14780 times)
Offline Mag_Pie
« on: 06 October 2015, 08:18 »
With the mornings staying darker on my way to work and now noticing the interior lighting, I appear to only have footwell lighting on the drivers side.  I'm right in thinking that there should be something on the passengers side as well aren't I?
I had a look on that side and I appear to just have a whole where I think the light should be.  I'm going to mention it at service time, I just hope that they believe I've not swiped it myself.
Offline p3asa
Re: Footwell lights - How many?
« Reply #1 on: 06 October 2015, 09:39 »
Yeah you should have 1 in both the passenger and drivers side.
I wouldn't wait for service personally as that is generally 12 months later.
Offline dv52
« Reply #2 on: 06 October 2015, 10:01 »
Yep, as p3asa says there are two foorwell lights at the front of the mk7.
Here's a pic showing locations (for LHD vehicle)
Don
103TSI Highline ROW (my13)
Offline Booth11
« Reply #3 on: 06 October 2015, 11:31 »
Have you had a feel around in the hole?  Perhaps the light fitting has become unclipped and gone back up into the cavity.  If it is completely missing, then as said, I wouldn't wait, I'd get it looked sooner.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline MXResonance
« Reply #4 on: 06 October 2015, 13:09 »
I was having a play around with the footwell lights last night and found that the passenger side light has a really short cable connector going to it, if someone else has been fiddling with the light I can easier see it being pulled back through the hole because of the tension on the cable.
Golf Mk7 GTI - DSG, Performance Pack, 5 Door, Pure White, 18" Austin, Discover Navigation, Keyless Entry, Factory Window Tints, Winter Pack - Collected 30/09/2015
Offline kevinm
« Reply #5 on: 06 October 2015, 16:02 »
Those lights are pushed in from the front so I really doubt it could have gone behind the trim. I cant see the light falling out as the wire to the light on the passenger side is very tight, as has been said above.
Current: His: 2020 M340i   Hers: 2019 GTD
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline GeoBog
« Reply #6 on: 06 October 2015, 20:45 »
Have you had the car serviced recently? There is a high chance that somebody nicked it. Or if it is new, most probably they haven't fitted it at factory.
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline Millzy68
« Reply #7 on: 06 October 2015, 21:56 »
I currently have a GTD but I'm due to collect an R in December, are the footwell lights and the door sill lights the same colour on the R as they are on the GTD ?
Offline GeoBog
« Reply #8 on: 06 October 2015, 22:03 »
No. The ambient lighting is:
GTD - white
GTI - red
R - blue
2020 VW T-Cross SEL
Offline Mag_Pie
« Reply #9 on: 06 October 2015, 22:04 »
Not yet, I'm wondering if it was a case of someone desperate for a spare part in a rush as it was pre reg. I need to have a good luck to make sure that it isn't hidden up in the dash first. I got the car in the 'light night' months so never really experienced full on darkness.
Thanks for the diagram dv52, I now know exactly where to check.
