Author Topic: Totally stuck with this clip....Help!  (Read 4795 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« on: 02 October 2015, 17:28 »
I put a new water housing on my Golf MK4 GTI Turbo 150.
Everything has gone to plan but I cant get the clip to hold the green temp sender in for love nor money.
Any ideas......
Offline itavaltalainen
Re: Totally stuck with this clip....Help!
« Reply #1 on: 02 October 2015, 17:55 »
Sensor not pushed in far enough?
Check that the flange does not already have o-ring in. If you have one on the sensor too then it won't go in all the way.
Once sensor is seated correctly the clip should be relatively easy to push on.
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #2 on: 02 October 2015, 18:23 »
Thanks bud
Pushed it as hard as I could with no joy. Flange does not already have an o-ring in.......Cant understand why it is not just clipping in as all the parts are from VW so not cheap ones off Ebay.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 02 October 2015, 18:25 »
the end of the clip goes right through to the other side of the housing too, it can be a bit of a struggle especially if it's all new...
worst case scenario you could always enlarge the slits on the housing outwards slightly with a hacksaw blade
Offline LR5V
« Reply #4 on: 02 October 2015, 21:57 »
that sounds odd, just saw your other post, spotted the clip is 90 degrees different in your original picture:
New:
Try the clip coming from the from the front of the Golf rather than the side?
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #5 on: 03 October 2015, 11:03 »
New:
Legend, thank you mate.....Clipped straight in  :smiley:
I cant believe I was trying to put it in the other way......Walks away with head down in shame  :embarrassed:
VW BUSH
« Reply #6 on: 03 October 2015, 12:59 »
do you wear slip on shoes :grin:
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #7 on: 03 October 2015, 13:18 »
Interesting you say that bud!  I had these on specially to help me put the clip on  :grin: :grin:
VW BUSH
« Reply #8 on: 03 October 2015, 13:58 »
Look like my work shoes :grin:
Offline LR5V
« Reply #9 on: 03 October 2015, 19:33 »
No worries fella - that is just the sort of thing I would do! - really glad you are sorted.
Is this AUM going into the Mk3 in your signature?
