Author Topic: Help, ignition not turning off  (Read 3301 times)
Offline jazz5000
« on: 27 August 2015, 00:01 »
Hi
Having a issue with my mk3
Once i start the car and turn it off, the ignition/engine wont turn off even if i take out the key
As soon as ignition is on, it wont turn off without a battery disconnect.
Would this be a immobilser fault?
As have ordered a bypass kit for that but had issues with a faulty board so waiting on a new one to see if it works.
Offline itavaltalainen
Re: Help, ignition not turning off
« Reply #1 on: 27 August 2015, 00:10 »
No, this has absolutely NOTHING to do with immobiliser. Bypass kit not required.
Although have just read your other thread..... rather than fit a bogus bypass thing just diagnose issue. Usually just a dead reader coil, or faulty chip.... if it's the latter just get a new transponder matched, anyone with VCDS or similar can do if you have the SKC.
Your problem with it staying is probably caused by a faulty ignition switch.... i.e. the electrical part of it (and usually only that in case you're thinking of getting the whole thing).
Replacement part is cheap but steering wheel needs to come off as well as bush behind it (puller required) so a bit of a fuff. Or other electrical fault or wrong connections made when transplanting engine.
« Last Edit: 27 August 2015, 00:13 by itavaltalainen »
Offline gasketface
« Reply #2 on: 27 August 2015, 01:12 »
Ignition switch replacement is fairly simple.you can leave steering wheel on and no puller is required.
See :- http://forums.vwvortex.com/showthread.php?3445064
I did one a week ago,took 30 minuts all done.
Offline LR5V
« Reply #3 on: 27 August 2015, 21:58 »
I used that method on mine - cant remember the other method I read about - but this one is easy.
nearly jumped out of my skin when the radio came a few seconds after the key was put in the ignition!
Offline jazz5000
« Reply #4 on: 29 August 2015, 14:55 »
Have just fitted a brand new oem ignition switch and still has the same issue  :cry:
Offline jazz5000
« Reply #5 on: 05 September 2015, 11:01 »
Bump
« Reply #6 on: 05 September 2015, 12:37 »
Get yourself a wiring diagram and trace from ignition switch to central electrics and so forth....
Offline gazareth
« Reply #7 on: 05 September 2015, 18:11 »
could be a sticking relay in fuse box :huh:
Offline jazz5000
« Reply #8 on: 13 September 2015, 21:03 »
Took out relay 72 (rear wiper relay) and it is fine now
