Author Topic: Anyone fitted a cruise control stalk??  (Read 5057 times)
Offline Bobbydazzlerr
« on: 22 August 2015, 16:42 »
Has anyone fitted a cruise control stalk and if so how easy is it and which one did you buy off ebay? Cheers
Full blueflame 3inch turbo back system sports cat, pipercross panel filter, revo stage 2 remap 290 bhp 350 lbft, neuspeed short shift, heko wind deflectors, forge blow off valve.
Offline 210GTi
Re: Anyone fitted a cruise control stalk??
« Reply #1 on: 22 August 2015, 21:48 »
Hi, I've fitted cruise control to my 2010 Gti , steering wheel and airbag req removal but apart from that just replace switch and then code to enable it- a worthwhile retrofit , cheers
« Reply #2 on: 24 August 2015, 09:18 »
Ordered a stork off ebay thanks for ure help
Offline SunnyGTI
« Reply #3 on: 24 August 2015, 10:20 »
I think there was a difference between 2009 models and later? I have read that the mk5 golf stalk fits the 2009 model and so is cheaper than the one fitted to the newer models...
« Reply #4 on: 24 August 2015, 12:20 »
331331977974 This is the item number off the one i have bought off ebay it says it fits mk5 and mk6 golf 2009-2013 i am not to sure if it will fit now you have said that haha
Offline joe6
« Reply #5 on: 24 August 2015, 16:35 »
I think the 2010 model and later requires both stalks as they come as a single unit and a new controller. This link helped me. The scirocco and mk6 are similar. http://www.sciroccocentral.co.uk/forum/viewtopic.php?f=38&t=14802&hilit=cruise+control+retrofit
« Reply #6 on: 24 August 2015, 22:20 »
It wont let me open that as i am not a member mine gti is a 2010 so if ure right it wont fit have to try and get my money back as the guy on ebay said it would fit so i need one that comes with 2 stalks as a full unit?
Offline itavaltalainen
« Reply #7 on: 25 August 2015, 16:04 »
Retrofitting cruise will depend on what hardware is in your car.
What part number is your BCM?
« Reply #8 on: 26 August 2015, 13:14 »
Wot is a bcm pal?
Offline Gaz-M
« Reply #9 on: 26 August 2015, 14:09 »
BCM is body control module.
A scan via VCDS will show BCM number and can check from there..
Ive been meaning to do the same.
