Author Topic: Led lights fitted bulb on dash vagcom help??  (Read 3616 times)
Offline Bobbydazzlerr
« on: 16 August 2015, 19:32 »
I have fitted led rear lights to my car and it has brought the bulb light on my dash can anyone help me do i need a vagcom? Or could it be done on a snap on computer not really after buying a vagcom just to remove the lights? Cheers
Full blueflame 3inch turbo back system sports cat, pipercross panel filter, revo stage 2 remap 290 bhp 350 lbft, neuspeed short shift, heko wind deflectors, forge blow off valve.
Offline mike.
Re: Led lights fitted bulb on dash vagcom help??
« Reply #1 on: 16 August 2015, 20:24 »
VCDS may help but potentially you will need a new BCM depending on the age of the car.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline golfhappy
« Reply #2 on: 17 August 2015, 07:29 »
Those darn bulb out errors again  :grin:
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
« Reply #3 on: 17 August 2015, 08:18 »
Wots a bcm mike? My car is a 2010 gti?
Offline dubber36
« Reply #4 on: 17 August 2015, 08:40 »
Body Control Module. In simple terms it's an ECU that controls certain electrical functions.
Your car being a 2010 should support LED rear lights with just some simple VCDS coding to erase the bulb out warning lights. Mine is the same age and works perfectly.
« Reply #5 on: 17 August 2015, 12:53 »
Is there anyone around the manchester area that would let me use there vagcom and i would pay dont fancy buying one just to do that or is there no other way to clear it?
Offline dubber36
« Reply #6 on: 17 August 2015, 13:41 »
PM The Doc, or find him at Carbon Chip Tuning.
Offline Rhyso
« Reply #7 on: 17 August 2015, 14:32 »
Doc hasn't been on here for ages mind  :sad:
There is a VCDS list on the forum under the garage section  :smiley:
Offline Gaz-M
« Reply #8 on: 26 August 2015, 14:15 »
2010 GTI just needs them enabled on VCDS as said. Done this on mine already.
LED registration lamps are a different story though  :angry:
Offline itavaltalainen
« Reply #9 on: 26 August 2015, 19:33 »
You can disable bulb check entirely on older BCM modules, though not sure if VCDS can do that, VCP can.
