Author Topic: Led lights fitted bulb on dash vagcom help??  (Read 3645 times)
Offline Thatsnotme
Re: Led lights fitted bulb on dash vagcom help??
« Reply #10 on: 26 August 2015, 20:30 »
If everything goes to plan I'll be fitting rear led's to my car tomorrow, however I'll then have the same problem as you... I'm also in the manchester area, if I find someone who is able to sort the error messages out I'll drop you a pm mate
Offline Bobbydazzlerr
« Reply #11 on: 27 August 2015, 07:38 »
Okay nice one my friends got a vagcom so will have to give it a bash getting annoyed off seeing the light on the dash now lol
Full blueflame 3inch turbo back system sports cat, pipercross panel filter, revo stage 2 remap 290 bhp 350 lbft, neuspeed short shift, heko wind deflectors, forge blow off valve.
Offline itavaltalainen
« Reply #12 on: 27 August 2015, 16:44 »
If he has vagcom it won't work. Too old to support CAN.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #13 on: 01 September 2015, 11:02 »
Dis able the bulb check only works on certain bcm for LED number plate lights. Iirc its 2011 on with the software for it. Earlier cars you can turn it off but you will get a light out error sooner or later as it doent turn it off completely due to the software.
Mk6 GTI  &  Mk1 GTI
35 years of GTI ownership.
