Author Topic: stop start function  (Read 3862 times)
Offline jpo
stop start function
« on: 12 August 2015, 16:46 »
Apologies if this is the stupidest thing anyone on here has asked but....
the stop start function. Doesn't seem to be on. Have checked that it is turned on and it is but i f i stop at light, put it into neutral the engine just keeps ticking over.
Offline Cossieian
Re: stop start function
« Reply #1 on: 12 August 2015, 16:51 »
Depends on a few different scinarios whether it works or not. ie if the engine is not at a certain temp, if the car is going through a regen, if you have the AC on etc etc
Current: MK7 Golf R (Limestone Grey) DSG, 19 Prets, Winter Pack, Rear Camera, High Beam Assist, Apple Connect, Gloss Black Mirrors
Gone: MK7 Golf R (Tornado Red) DSG, Winter Pack, Keyless, Gloss Black Mirrors
Gone: MK7 Golf GTD (Pure White)
Offline jpo
« Reply #2 on: 12 August 2015, 16:54 »
Thanks for the reply. Makes sense as i had the aircon on.
Offline fredgroves
« Reply #3 on: 12 August 2015, 17:01 »
You should get a A in a circle with a line through it on the MFD (between the speedo and the rev counter).
Just because air con is on, doesn't mean it won't stop btw.... only if its actively heating or cooling. If you have climate set to auto and the temp inside the car is the same as you set then auto stop will work.
And take your foot off of the clutch!
« Last Edit: 12 August 2015, 17:07 by fredgroves »
Offline jpo
« Reply #4 on: 12 August 2015, 17:08 »
Ha ha!!!
I actually realised last night i was using the clutch way too much! Have put the handrake on the auto thing (realise how uneducated i sound) and am slowly getting used to it!
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 12 August 2015, 17:25 »
I have a list somewhere of the criteria for the stop-start to function, it really is ridiculous. Apparently you need to have your seat belt on too!
Offline itavaltalainen
« Reply #6 on: 12 August 2015, 18:30 »
Why is it ridiculous?
All about energy management and to some extent comfort of the passenger (e.g. actual temp within 8 degrees of set temp).
@OP How do you use a clutch too much?  :shocked:
Offline remlapeel
« Reply #7 on: 12 August 2015, 21:50 »
Some of the criteria are stupid .....steering angle to great for example.
Apparently you're not allowed to stop in traffic on a tight corner lol
2015 MK7 Golf R 3 door, DSG, lapiz blue, 19" wheels, winter pack, keyless entry, dynaudio and high beam assist.
Offline J400uk
« Reply #8 on: 12 August 2015, 21:52 »
I find in mine you need to apply a certain level of pressure to the brake pedal for it to kick in, otherwise the engine remains on. Find it quite convenient as if I know I'm only going to be stopped very briefly then you can avoid it coming on.
2015 Golf GTD 2.0 TDI 184 PS 6-speed DSG 5 Door Tornado Red
Offline AndyG
« Reply #9 on: 12 August 2015, 22:24 »
I agree with this.If you regulate the amount of pressure applied to the break pedal,the engine won't cut out.If I am going to be stopped for some time I simply put the break pedal to the floor and the engine usually cuts out,unless I have the air con on full soon after starting a journey.I get the impression that it works more favourable with DSG,don't know if I am right with this assumption though.
Golf 7R,DSG,5 door White,leather,rear camera.
