Golf mk3
hardmonkeys
MOT fail-need advice..
Topic: MOT fail-need advice.. (Read 4778 times)
Jasikasisback
27 July 2015, 17:21 »
So took the Golf for the MOT today...and it failed..
This is what it failed on.
RBT service brake efficiency 41% (what does that mean?)
Emissions- (this can be passed in future as car was not even close to warm when tested..)
Front front brake binding 3.7.B.1
Rear brake valve damaged 3.6.A.2c-this was what I expected it to fail on..
Nearside rear wheel bearing has excessive play 2.6.2
Offside rear wheel bearing has excessive play 2.6.2
Service brake: efficiency below requirements 3.7.B.7-probably just needs tightening I hope..
So will need advice on the bearings and how to sort them and the front brake binding issue..
Can I remove the bearings and get them back in without a press?
Last Edit: 27 July 2015, 18:07 by Jasikasisback
madmanmart
Re: MOT fail-need advice..
27 July 2015, 18:13 »
As the rear wheel bearings are tapered, you can pinch them up it remove the play. Don't over tighten them though.
Front brakes want a strip and re greese, rears want the same and handbrake adjusting.
Couple of hours work.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Jasikasisback
27 July 2015, 18:55 »
Do I need a special tool to replace the rear brake valve ??I think I will try to save this car as not much wrong with it really..
madmanmart
27 July 2015, 19:09 »
Brake pipe spanner and Alan sockets
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
27 July 2015, 19:24 »
Tbh with rear bearing they are changed so easily that I'd just replace them. 10£ a side with OEM quality parts.
With these MOT results I'd take rear brakes apart and see if they are still serviceable and if they are relubricate.
Jasikasisback
27 July 2015, 19:29 »
I will have a look..they were inspected a couple of years ago and it was noted that they are in good shape...will post pics so you guys can see (I have never been able to post pics here so will be via a link in flickr...) Will go outside now and do some..I saw the spanner it is called a flare nut ?what size will I need?
Going out to do some photography now...may make a small movie as well..
Foreveryoungaus16v
Reply #6 on:
27 July 2015, 19:54 »
Yeah definitely replace both rear wheel bearings and I would just replace the discs too
KW V2, TEAM DYNAMICS PRO RACE 1.2, EIBACH ARBS, DS 2500 PADS, BLACK DIAMOND DISCS, LIGHTENED FLYWHEEL, CHIPPED ECU, VIBRA TECHNIC MOUNTS, JETEX DECAT, FULLY POLYBUSHED
163 BHP (TSR POWER RUN)
Jasikasisback
Reply #7 on:
27 July 2015, 20:56 »
Put photos and some video on Flickr..please have a look and tell me what you think.
vwgolfcl1996...
Maybe I'm just going mad...
madmanmart
Reply #8 on:
27 July 2015, 22:22 »
No point replacing the bearing if there's nothing wrong with them, just might need pinching up.
Jasikasisback
Reply #9 on:
27 July 2015, 22:45 »
Any step by step for that as can give it a go tomorrow...
Golf mk3
hardmonkeys
