Author Topic: MOT fail-need advice..  (Read 4772 times)
Offline madmanmart
Re: MOT fail-need advice..
« Reply #10 on: 27 July 2015, 22:55 »
It is possible with the wheel on but I always remove it.
Remove car from centre of hub.
Remove split pin
Lightly tighten the 24mm nut, I always set my cars so they have the tiniest bit of play.
Refit, job done.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline Jasikasisback
« Reply #11 on: 28 July 2015, 01:49 »
thanks,
I will give it a go tomorrow..
This may sound stupid...but how will I know I have done it correctly..? Will tighten it up slightly and see what comes of it..
Offline Simeon
« Reply #12 on: 28 July 2015, 08:06 »
Adjust rear bearings with wheel fitted as this allows you to adjust the play properly
Offline Foreveryoungaus16v
« Reply #13 on: 28 July 2015, 10:43 »
No point replacing the bearing if there's nothing wrong with them, just might need pinching up.
I would especially if you don't have any idea when they were last done. For the price of the bearings and labor it's a no brainier. Plus then you know that side of things has been done. Up to you, just know what I would do.
« Last Edit: 28 July 2015, 10:45 by Foreveryoungaus16v »
163 BHP (TSR POWER RUN)
« Reply #14 on: 28 July 2015, 12:22 »
I am planning to keep this car on the road so will replace the bearings and will replace the rear brake pressure regulator...the front brake pads are thin..but can be replaced at some point later I would hope..first I have to get the car through the MOT and if I can get it through with a retest within a week then that would be great as I don't want to shell out another £40-50 for just the MOT. If anyone wants to give me a hand I would appreciate it, but I will try it myself and see how it goes...there are lots of videos online and I have a Haynes manual so I will give it a go..I will make a list of all the stuff I will need to buy so it can be verified that I am not missing anything and will post it here. The car should be ok for one more year. If it fails emissions again I will consider it a learning experience. I didn't even know a whole lot about cars before I owned this Golf...and the learning curve is a steep one for me..but I am willing.. :grin:
