Author Topic: blooming car won't start! engine swap 1.3 - 1.8 on twin 40's  (Read 3077 times)
Offline luiethemk2
hello all, I've recently done an engine swap from my wee little 1.3 to an 1.8 gti, removed the gti inlet and converted it to carbs, twin 40 webers to be exact.
the new engine works as I drove it home, it sparks, is getting fuel, turns over but won't just fire and go..
I've uprated..
red top fuel pump
malpassi filter king regulator
Sytec adjustable fuel regulator
Lucas high output coil pack
Magecor 8mm ht Leads
and standard service
so any advice that be grand :)
Offline gazareth
what distributor are you using? k-jet or digi?
Offline luiethemk2
It is digi
Offline Sgt_Lemon
  • 8v owners club
I bet money on ignition timing. You need the dizzy loose and to twist it back and forth as someone cranks it.
Offline luiethemk2
cheers sgt lemon, I shall let you know if it works, one other thing tho, I swapped the brake servo over and now the far left carb filter won't fit, what have people done, i can't run it without a trumpet or filter
Offline luiethemk2
Ok moved the dizzy around while the engine was cranking, it made no difference what's the ever, any other clues?
Offline gazareth
have you blocked of fuel injector ports in head? also a digi dizzy is no use as it has no mechanical advance. you need an early mk2 k-jet one or even late mk1.
Offline luiethemk2
I've left the injectors in, thought that would work unless you have a better idea? so would a dizzy of a 1.8 driver work?
Offline gazareth
yeah leaving the injectors in wouldn't cause an issue. yeah driver dizzy would be a step in the right direction but the gti one has a better advance curve for your engine spec.
Offline luiethemk2
do you know of a better option then leaving the injectors in.. some sort of plug?
ahh ok I search one! thank you
