Author Topic: Wheel and shell vibration.  (Read 2847 times)
Offline UnCl3RoRy
  • Silver - 2001 1.8T AUM
« on: 11 June 2015, 22:03 »
I've got some slight wheel and shell vibrations after having coilovers fitted (Jom), a tt arb and spacers (5mm) at the front. Now at motorway speeds the steering wheel vibrates and I can also feel it through the seat. Anybody tell me why? I was fine before I fitted these parts.
« Last Edit: 11 June 2015, 22:08 by UnCl3RoRy »
If you no longer go for a gap that exists, you are no longer a racing driver - Ayrton Senna
Offline itavaltalainen
Re: Wheel and shell vibration.
« Reply #1 on: 11 June 2015, 22:18 »
Bolts all tight?
Vibration dependent on speed?
Offline UnCl3RoRy
« Reply #2 on: 11 June 2015, 22:21 »
Yeah I've checked the bolts, it happens at around 70mph.
VW BUSH
« Reply #3 on: 11 June 2015, 22:59 »
Spacers are hub centric?
Offline UnCl3RoRy
« Reply #4 on: 12 June 2015, 06:54 »
Yep hub centric
Offline Technane
« Reply #5 on: 12 June 2015, 13:20 »
had it tracked since making all those changes?
« Reply #6 on: 12 June 2015, 13:32 »
When had you wheels balanced last?
You wheels are now further out, which can amplify any imbalance, particularly at higher speed.
Offline Mr_Orange
« Reply #7 on: 12 June 2015, 15:35 »
Hubcentric 5mm? Is there such a thing? You sure your wheels are sat correctly on the hubs?
Build thread clicky
Offline UnCl3RoRy
« Reply #8 on: 12 June 2015, 17:51 »
Haven't balanced the wheels since I bought the car nearly 2 years ago.
I bought the spacers from eBay.
VW BUSH
« Reply #9 on: 12 June 2015, 20:19 »
