Author Topic: Passed the MOT! but there's still 'something' wrong  (Read 2940 times)
Offline Ajay
Hi All,
The car: 1991 Clipper with a 1999 1.8t AGU Engine fitted.
Passed the MOT yesterday but still stank of fuel =/
I had some fun with VagCom yesterday and I got some readings I just don't understand - I think there's something way off with the Lambda sensor but I have no idea which one is which. Also there are 2 temperatures...???
Outputs are below...
Any help?
P.s - not sure if this in the right forum
Al
Offline Technane
Re: Passed the MOT! but there's still 'something' wrong
« Reply #1 on: 09 June 2015, 15:59 »
First off the MOT means nothing to do with the engine, it just ensures road worthy / emissions.
read the fault codes off it with VCDS then post them here.
Offline Ajay
« Reply #2 on: 09 June 2015, 20:20 »
16885 - Vehicle Speed Sensor (G22): Implausible Signal
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
26-10 - Output Open
18259 - power train data bus:
Missing message from ABS controller
P1851-35-00
None of the above exist on the car anymore - no other fault codes.
Offline Ajay
« Reply #3 on: 09 June 2015, 20:25 »
Offline Technane
« Reply #4 on: 10 June 2015, 15:36 »
Just clearing the faults doesnt mean the faults gone, clear the fault drive the car about see if the fault comes back
anyway 01247 could be a fake so ignore,
16885
http://wiki.ross-tech.com/wiki/index.php/16885/P0501/001281
So looks like an ABS fault, but that ays to me you should have an ABS light on your dash which is an instant MOT fail
Read the ABS module and check for fault, Check fuses aswell
Offline Ajay
« Reply #5 on: 10 June 2015, 18:56 »
Faults were cleared the day before picture was taken, the same three remain.
Prehaps I need to be more clear, as per my original post, the car is a 1991 conversion - it has never had ABS so the module cannot be read as it no longer exists hence why there is no ABS warning light to fail the MOT. I am aware of the speed sensor fault, this is part of the ABS system... which does not exist... The charcol sensor, i'm also aware of this fault.. because the charcol filter also no longer exists.
Fault codes on this occasion are not going to help me
The purpose of my post is to find out from anyone who knows, why my car is telling me that the lamda is reading at 25%, and why there are three different readings... If there's three sensors on the AGU.. where are they?
If the moderators feel this would be better suited in 'The Garage' or in the VagCom forum, please let me know
Al
Offline itavaltalainen
« Reply #6 on: 11 June 2015, 22:20 »
G22 is not ABS I think but vehicle speed sensor in gear box  :nerd:
Offline Ajay
« Reply #7 on: 14 June 2015, 12:19 »
Anyone have any more input?
PLEASE NOTE: I'm looking for the answer to the high lamda readings
