Author Topic: Mk7 Rear Bumper paint rubbing off?  (Read 13911 times)
Offline paulfromthehill
Re: Mk7 Rear Bumper paint rubbing off?
« Reply #10 on: 07 May 2015, 17:49 »
My 63 plate GTD has been into the local dealer today with exactly the same problem.  Boot is being realigned, awaiting confirmation as to what will happen with the paintwork.
Offline difficultrogue
« Reply #11 on: 23 June 2015, 18:27 »
I after 500 miles from new have the very same problem!
Was there a definitive solution for this problem?
Offline JamesR27
« Reply #12 on: 23 June 2015, 21:30 »
I had similar, but not as bad as the pics here. I took it straight to VW and they realigned the boot and fortunately they polished out the marks.
Mk 8.5 Clubsport Pure White, Queenstown, DCC.
MK 7.5 R Pure White, Pretoria Silver, DCC, Rear Camera.
Gone - MK 7 GTI Carbon Grey, Rear Camera, Service Pack.
Gone - MK 6 GTI  Reflex Silver, Monza Shadows, RCD 510, Rear Camera, Bluetooth, Tyre Pressure Sensor, Xenons Convenience pack, Service Pack :)
Gone - MK 5 GTI Reflex Silver, Monza II 18's, Luxury Pack, Mulitchanger
Offline GrahamFR
« Reply #13 on: 24 June 2015, 11:27 »
I have this too, will drop it into VW as soon as I get chance
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline Chief1337
« Reply #14 on: 24 June 2015, 12:03 »
Exactly the same issue and this thread has just reminded me to book the car in to get it sorted.
Will keep you all posted.
Offline Chief1337
« Reply #15 on: 29 June 2015, 15:10 »
So the car is in the dealers today to have this looked at. Apparently, there are signs of 'wear' on the bolt that hold the boot in-place as if someone has previously taken a spanner to them! Well it certainly wasn't me I reply to Mr Customer Service agent...
He's apparently now taking it to the bodyshop for them to take a look..
If it's alignment (which it's looking like it is) this isn't apparently covered by warranty as is considered 'wear & tear' unless reported in the first 6 month's of ownership/1,000 miles. Similar to wheel and door alignment so they say.
Not happy - so going to argue the point once the bodyshop have had a look.
Other have got this done under warranty right? How old was the car at the time?
Offline Jimble
  • Moderator
« Reply #16 on: 30 June 2015, 10:42 »
This is how my first mk7 looked the day i collected it, someone had adjusted it either VW or the dealership however the dealership denied it so.... :rolleyes:
Offline JoeGTI
« Reply #17 on: 30 June 2015, 10:45 »
I've seen that on loads of MK7's, including a little bit on my own. It's done in the factory. They obviously adjust a few nuts and bolts after they've painted it...
Offline Chief1337
« Reply #18 on: 30 June 2015, 11:39 »
Thanks Guys - so collected the car and they basically said this won't be covered under warranty as it's not within 6 months / 6,000 miles and there are no 'failed parts'.
Waiting for the quote but they have said the bodyshop will need to realign/adjust. They can see clear previous 'adjustment' (paint rubbed off) on the bolt/boot area which they showed me. No history that this has ever been done and I certainly haven't touched it!
Very interesting that you guys are also seeing a similar issue and evidence that this is clearly adjusted at the factory AFTER painting! I'll use this in discussions with them.
Do you think I should challenge directly with VWCS?
Update: Email from dealer "I have checked 2 other golfs and the hinges are pained at factory on the tailgate and then fitted all of the other  cars have no markings on the bolts or unpainted areas showing on the tailgates."...
Not happy. :-(
« Last Edit: 30 June 2015, 14:23 by Chief1337 »
Offline Jimble
  • Moderator
« Reply #19 on: 30 June 2015, 15:00 »
I'd contest it mate, as Joe says there are loads about that had the tailgate adjusted prior to delivery.
