Author Topic: Xenon retrofitting  (Read 24781 times)
Offline dubber36
Re: Xenon retrofitting
« Reply #20 on: 26 April 2015, 11:18 »
What gets me is why it can't be straightforward?
With halogen lights there is a wire that goes to the main beam bulb and illuminates it when it's powered. Why can't the same wire be powered to keep the shutter in the main beam position on a xenon lamp in just the same way?
Offline golfhappy
« Reply #21 on: 26 April 2015, 11:34 »
Checked my old BCM 086M and it doesn't have the shutter wires.
Think some wise owls actually worked that out that the high beam power would trigger the shutters. Think Hawkeen on the American forum did some cleaning up of the wiring diagrams which were floating about.
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline Screech
« Reply #22 on: 26 April 2015, 11:49 »
The wiring adaptors that came with my lights, allow the shutter to work. I plugged them in before handing the money over and was surprised when they flicked up!
Not sure if they work with lights off though, think that may just be a bit of coding too?
Offline golfhappy
« Reply #23 on: 26 April 2015, 12:05 »
Did the harnesses have a long wire coming from them, if not i think i know where they came from. You really want to document them. Photos if possible.
Offline golfhappy
« Reply #24 on: 26 April 2015, 12:59 »
And here we are, look at posts 191 and 192 in this link. http://forums.vwvortex.com/showthread.php?4587617-Bi-Xenon-retrofit-on-golf-mk6/page6
Offline mike.
« Reply #25 on: 26 April 2015, 13:25 »
And some more info HERE.
Is it still possible to get the AFS module to work with this workaround or does that need the 087 version?
« Last Edit: 26 April 2015, 13:32 by mike. »
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Screech
« Reply #26 on: 26 April 2015, 14:09 »
Ohh, more helpful links, and there was me thinking I must've read all of them with the amount I have read on this subject!
Mine have no long leads to go to the bcm, the sh!tter wire is from what would've been the high beam wire. I've already I taped it and checked it out. I'll grab some pics later.
I'm hoping afs won't be affected by what bcm is fitted, fingers crossed!
Offline golfhappy
« Reply #27 on: 26 April 2015, 15:14 »
Me thinks we'd have to either start looking at an auto scan for a golf R? It has AFS it would be interesting to see BCM version.
As for info bucket loads out there, bit of a mine field!
It wasn't until i asked Mike the question "are the kufatec adaptor wires joined together" they would make the loom like that.It isn't until you dig deeper that you find out that some of the main looms are different. We used this http://volksurf.blogspot.co.uk/2011/09/bi-xenon-led-retrofit-diy.html and if you read down think its in red writing about joining the wires 10 and 12 to get the leds to work. What a pain that gave me!
Plus when i checked lots of long codes my byte 13 was 04, everybody's is 00. I asked Ross Tech and they said undocumented byte they didn't know what it did. It may well have been like byte 18 with 00 hiding the real code. I just went for it and changed it to 00 and with Mike's long code help all went well  :grin:
« Last Edit: 26 April 2015, 15:19 by golfhappy »
Offline Screech
« Reply #28 on: 26 April 2015, 15:47 »
I'd imagine all cars with xenons from the factory will have the 087, as they will have the shutters wired 'properly'.
Tbh, any threads that I've read that say join 2 wire together I've pretty much stopped reading, I don't wantbto bodge it, I wantbto do it properly.
Offline golfhappy
« Reply #29 on: 26 April 2015, 17:00 »
1K0 937 084 G  Part number for a Golf R with xenons not led...?
