Author Topic: tire pressure loss ind- error  (Read 15918 times)
Offline torsan
Re: tire pressure loss ind- error
« Reply #10 on: 24 August 2015, 14:47 »
so my wife's new mk7 displayed a 'tire pressure loss ind- error' on the MFD a couple of times.  Does this refer to pressure loss (i checked all wheels, no pressure loss), or a fault with the actual sensor system?  It's a brand new car with less than 1000 miles on it.
Hi candywhite12,
Finally did you manage to find a solution for this problem? I have the same error message coming up in my brand new car... I'm just curious if there is a simple solution before I take the car to the service. Thanks in advance!
Offline candywhite12
« Reply #11 on: 24 August 2015, 15:00 »
Hi candywhite12,
hi there.  not really, it does come up from time to time with no apparent reason - whenever I check tires they are ok - so i guess i will be waiting till its first service to check it out.  let me know how it goes with yours in case your service comes earlier
Current: GTI 8.5, Moonstone Gray, 5dr, Black Estorils 19''. pan, DCC
Wife's: mk8 TSI 1.5 RL, 5dr atlantic blue, DSG, Norfolk 17", pan s/r, leds
Son's: mk7.5 TSI 1.4 RL, 5dr tornado red, DSG, Singapore 17", pan s/r, leds
Before: mk6 GTI 5dr candy white, DSG, Monza Shadow 18", s/r, bi-Xenons, DCC
Even before that: mk5 GT 5dr tornado red, manual, s/r
Offline torsan
« Reply #12 on: 25 August 2015, 10:46 »
Hi candywhite12,
Thanks for your response! Sure, I will come back to you if I have any update on this from the service... However it will take some time, my car has done only 400 kms so far. My guess is that some software update or service reset will solve the issue. We'll see...
Offline itavaltalainen
« Reply #13 on: 25 August 2015, 13:07 »
If you have really strong changes in temperatures the pressure and shape of tyre change.
As I recall it was very hot in Hungary the last few months, but has been more fluctuating down to the teens.... that can upset pressure warning system as it is improved over previous gens. Had the same thing last year on winter holiday in Austria. -10 degrees, checked pressure, pumped tyres up a bit, reset pressure. Back in the UK after a bit of harsher driving at +10 I got a pressure warning, all OK and roughly where I pumped them up to in Austria.
Sometimes it just needs a reset.
Offline fredgroves
« Reply #14 on: 25 August 2015, 14:09 »
^^^^^^100% agree.
Don't waste your time asking the dealer!
Offline torsan
« Reply #15 on: 25 August 2015, 14:23 »
That's true it was very hot in Hungary in the last few months, and it probably can fool the tyre pressure system... But actually not the tyre pressure loss yellow warning light comes on, but randomly I get the "Tyre pressure loss ind_ error" message when I turn the ignition on. This is so weird... I tried the reset, but the error message keeps on popping up randomly.
Offline corgi
« Reply #16 on: 27 August 2015, 16:55 »
That could be down to some fault in the system, a random value from a sensor... however, if it were an ABS sensor I would expect the car to be reporting ABS errors as well... Electronics don't much like extremes of heat or cold...
Corgi
« Reply #17 on: 27 August 2015, 18:54 »
So it's an error on tyre pressure monitoring rather than tyre pressure warning?
If so off to dealer or at least someone with VCDS.
Offline Gingernick
« Reply #18 on: 01 September 2015, 14:43 »
mine came on unexpectedly on a drive down to masham last year..pulled over and checked everything and all was well...reset it and its never uttered a dicky bird since
3dr Gti, manual, tornado red, performance pack, dynaudio. gone now
5dr GTi, manual, red, Performance pack, dynaudio
going
5dr Gti, Manual, performance pack , indium grey (for a change!)
