Author Topic: tire pressure loss ind- error  (Read 15895 times)
Offline candywhite12
« on: 15 April 2015, 19:52 »
so my wife's new mk7 displayed a 'tire pressure loss ind- error' on the MFD a couple of times.  Does this refer to pressure loss (i checked all wheels, no pressure loss), or a fault with the actual sensor system?  It's a brand new car with less than 1000 miles on it.
Current: GTI 8.5, Moonstone Gray, 5dr, Black Estorils 19''. pan, DCC
Wife's: mk8 TSI 1.5 RL, 5dr atlantic blue, DSG, Norfolk 17", pan s/r, leds
Son's: mk7.5 TSI 1.4 RL, 5dr tornado red, DSG, Singapore 17", pan s/r, leds
Before: mk6 GTI 5dr candy white, DSG, Monza Shadow 18", s/r, bi-Xenons, DCC
Even before that: mk5 GT 5dr tornado red, manual, s/r
Offline itavaltalainen
Re: tire pressure loss ind- error
« Reply #1 on: 15 April 2015, 19:55 »
Just teach it pressures again.
« Reply #2 on: 15 April 2015, 20:03 »
i have, it pops up every now and then (only momentarily though and only when i switch the car on)
Offline scotland67
« Reply #3 on: 15 April 2015, 20:05 »
Happened to me yesterday, warning came up. I checked tyres visually asap and with a gauge when I got home.
No apparent loss of pressure in any tyre
Reset the moniterand so far so good.
Offline 182_blue
« Reply #4 on: 18 April 2015, 16:24 »
Apparently stones stuck in tyre treads can cause the monitor to mis read.
« Reply #5 on: 18 April 2015, 17:34 »
seriously now?
Offline 182_blue
« Reply #6 on: 18 April 2015, 18:33 »
seriously now?
Not sure i understand ?
« Reply #7 on: 18 April 2015, 18:36 »
seriously now?
i get it its included in the basic package but surely VW could find a way to make this work without hinches... the tire pressure monitor i have on my mk6 has not malfunctioned ever...
Offline 182_blue
« Reply #8 on: 18 April 2015, 18:45 »
seriously now?
I am not saying it doesn't work, mine has been faultless, VW use an indirect system on the MK7 (as they did on the 6 & 5 etc) ,i.e there are no sensors in the tyre itself and therefore it relies on the ABS sensors to tell it that the tyre is out of shape, obviously this is a little open to false readings and not as good as a direct system.
Offline mk7gti
« Reply #9 on: 18 April 2015, 19:41 »
I normally get an alert around this time of year as the road temperatures begin to warm up. A simple reset of the tire pressure system should sort the issue. Just confirm all the tyre pressures match first.
MK7 GTI - Deep Pearl Black - Standard Spec - Ordered 10/12/2015.
MK7 GTI - White - Standard Spec - Service Pack - Collected 11/09/2013.
