Author Topic: Still getting bad maf problems  (Read 4019 times)
Offline reedy20vturbo
« on: 13 April 2015, 22:45 »
Hello, I'm still having trouble finding out why my car keeps eating maf sensors, (1.8t Aum) I've put 4 new genuine ones on in the past year and they last a month tops before they compleatly go,  within a week the car starts to get a flat spot, and by the End of the month it gets that bad that I get about 2psi of boost and the car runs like a pig and it's just about un drivable, I disconnect it at it runs perfect, it's not remapped, I just have a few basic mods, but it's done it ever since I brought it, and it was standard when I got it, has anyone had this problem? It's becoming that much of a pain it's making me want to get rid of it haha, I have vag com I have no fault codes only one witch is because of my decat, but with the maf disconnected,  the tc light comes on and I get a system to rich and a maf sensor implausible signal or something, really stuck now, any help will be much appreciated,  cheers
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Still getting bad maf problems
« Reply #1 on: 14 April 2015, 02:04 »
What sort of filter do you have on it?
Some of the aftermarket ones which you have to oil can corrode or cause the MAFs to fail prematurely...
« Reply #2 on: 14 April 2015, 07:23 »
I have a honda s2000 on it it now but I did have the standard airbox and it still did itt then
Offline Dalo Harkin
« Reply #3 on: 14 April 2015, 12:46 »
The Green S2000 filters are not oiled and the red ones are from what I have seen, the problem with it not being oiled is that small particles can still still get in, the oiled ones pull the oil in... both will prematurely kill the MAF.
Have you tried cleaning the MAF rather than replacing it? CNC cleaner I think its called is what I use
« Reply #4 on: 14 April 2015, 17:37 »
I do have a red one but I'm pretty sure it wasn't oiled as it was dry and you can normally tell if they have been oiled, I've literally tried everything and it still keeps doing it,
Offline Dalo Harkin
« Reply #5 on: 15 April 2015, 12:49 »
They don't look oiled, but I'm 99.9% sure they are.
get some of the CLC cleaner and give that a whirl and see how you get on, how long have you had the S2000 filter on, as they are paper they are classed as a serviceable item so need replacing yearly if not sooner
« Reply #6 on: 15 April 2015, 17:23 »
Yeah I've tried it already mate, what confuses me is why it still did the same thing with the standard airbox, I like the noise of the cone filter, can you recommend a set up that still gives you good noise but won't kill the maf? Thanks
Offline Dalo Harkin
« Reply #7 on: 16 April 2015, 17:25 »
If you've killed a few MAFs its usually from oil based filters because as it sucks the air in it loosens the oil and the oil attaches the wire, the MAF works by heating a thin piece of wire up and as the air flows over it, it cools it down, more speed = more air
You want a non oiled filter really, I tried loads of options and finally settled again on a smoothed airbox with a DSG intake and a pipercross panel filter
« Reply #8 on: 16 April 2015, 19:26 »
Ok mate thanks for the info, what do you think to your current set up? Do you get much turbo noise?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 17 April 2015, 18:15 »
If you want noise, either a cheap cold air intake with a decent cone on the end or carbonio will be your best bet. My carbonio is fairly loud lol
