Author Topic: Best cleaner for stock chrome exhaust (Polo GTI)  (Read 4606 times)
Offline pologti2012
« on: 03 April 2015, 00:02 »
Hi there looking to clean the dirt/soot off my Polo GTI which has the standard twin exhaust. Dont want anything too abrasive that would peel the chrome finish. Any ideas  :undecided:
Offline Booth11
Re: Best cleaner for stock chrome exhaust (Polo GTI)
« Reply #1 on: 03 April 2015, 00:22 »
Mothers Mag and Aluminium Polish
http://www.elitecarcare.co.uk/mothers-mag-and-aluminum-polish-5oz-141g.php?manufacturers_id=78&osCsid=qceeue3828v3s27vo5r52iqd33
http://www.amazon.co.uk/Mothers-Mag-Aluminium-Polish-5oz/dp/B00068GEJM
For baked on carbon deposit try it with some fine grade 000 steel wool.  Work the polish in with the wool, you'll need to put some effort into it, but be gentle as it will scratch if you're overzealous.  Buff to a shine with a soft microfibre.
Also often recommended are Autosol Metal Polish and Britemax Twins (which is a 2 stage cleaner/polish/sealant)
This was result using Mothers. Not the best before pics but they've been worse and still come up nice and shiny.
Before
After
« Last Edit: 03 April 2015, 00:59 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline pologti2012
« Last Edit: 03 April 2015, 01:01 by pologti2012 »
Offline Wo-Wo
  • www.wo-wo.co.uk
« Reply #3 on: 03 April 2015, 10:45 »
Britemax metal twins all day long, the best metal polish I've ever used and as Booth says it has a separate sealant too.
Offline Gazza
« Reply #4 on: 03 April 2015, 15:24 »
Another one for the metal twins.
Offline Golf-Ball
« Reply #5 on: 05 April 2015, 17:55 »
Autosol. You can buy it from the high street, it's cheap, and in my opinion it's beter than the other products you've lsited
Offline Booth11
« Reply #6 on: 05 April 2015, 20:08 »
I know Autosol has a bit of a cult following and I used to use it but was always disappointed with the result.  Even when well worked it struggled to shift caked on soot.  I also tried Auto Finesse metal polish but found that to be almost identical to the Autosol.
Switched to Mags and haven't looked back.  Mind you I fancy trying the Britemax metal twins as it gets such rave reviews.  My pot ofvMags is almost finished so might get some of that next.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
