Author Topic: failed MOT  (Read 3904 times)
Offline Scottymk4
failed MOT
« on: 30 March 2015, 15:29 »
car failed on all this today, anyone give me a rough idea of how much to fix?
Offside Front position lamp(s) not working (1.1.A.3b)
Front registration plate deteriorated (6.3.1d)
Offside Front Brake hose excessively deteriorated (3.6.B.4d)
Nearside Front Tyre(s) incorrect because different size tyres are fitted on the same axle. (4.1.A.1a)
Nearside Rear coil spring broken (2.4.C.1a)
Offside rear parking brake recording little or no effort (3.7.B.6a)
Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.D.3)
Parking brake: efficiency below requirements (3.7.B.7)
Advisory Notice issued
Nearside Front Brake hose slightly deteriorated (3.6.B.4d)
Nearside Rear Brake pipe slightly corroded (3.6.B.2c)
Offside Rear Brake pipe slightly corroded (3.6.B.2c)
cheers
Scott
Offline barrym381
Re: failed MOT
« Reply #1 on: 30 March 2015, 17:48 »
probably 100quid in bits and the same to fit them  :smiley:
Offline hardmonkeys
Re: failed MOT
« Reply #2 on: 30 March 2015, 17:51 »
Not a bad fail sheet really..I'd say the same as previous poster...give or take £30-£50
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'0 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: failed MOT
« Reply #3 on: 30 March 2015, 19:53 »
No rear brake effort - you will probably have to buy a new caliper to sort this
Brake line - You might as well replace all of them as the others are on their way
Emissions - probably be the cat or lambda, you'll need a quick go on VAG COM to work out which
Tyres - get one to suit whichever you want to keep on the car
Reg plate - any decent accessories shop will sort this for you for around a tenner
Spring - find a PAIR from a scrapper
Parking brake - this is probably the same fault as the "no rear braking effort"
Offline Scottymk4
Re: failed MOT
« Reply #4 on: 30 March 2015, 21:22 »
Thanks for the reply guys... Barry you were spot on £100 for parts and same to fit
Offline barrym381
Re: failed MOT
« Reply #5 on: 30 March 2015, 21:38 »
knew it wouldn't be far from that  :smiley:
Offline shaft69
Re: failed MOT
« Reply #6 on: 02 April 2015, 00:15 »
How did you get tyre sizes different  on same axle??
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline barrym381
Re: failed MOT
« Reply #7 on: 02 April 2015, 22:37 »
he let a caveman sort it  :grin: :grin:
Offline Scottymk4
Re: failed MOT
« Reply #8 on: 07 April 2015, 16:15 »
hahaha, it was the spare I had put on cause I got a puncture :grin:
