Author Topic: My golf mk4 1.8t  (Read 114193 times)
Offline shaft69
My golf mk4 1.8t
« on: 22 March 2015, 12:12 »
Never ending mk4 project spec as it stands currently sorn'd
1.8t AUM engine 2001 167k milles
ko4 turbo
380cc injectors
3" maf
3" downpipe with sports cat to 2.5" milltek
Dual nozzle water/meth with harris performance controller run 50/50
unitronic stage 2+ tune running 276hp/301lbft tq without meth
H&R coil overs
H&R front/rear ARB's
AP racing 334mm front brakes now replaced with R32 front brakes rears standard will replace with bigger soon
Genuine R32 18" rims powder coated black.
Engine now had its day building new engine
bought 50k mile AUM engine AGU cylinder head
block completely stripped, cleaned, bored, honed and painted all parts fitted will be brand new.
Blocked bored to 82.5mm with tsi forged crank, supertech stroker pistons and intergrated eng rods giving 1984cc all ancilleries will be brand new.
AGU head stripped, cleaned, new valve guides, supertech high temp valve seals and race exh valves
All hardware used ARP bolts, main and bigend bearings ACL race bearing.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Scott-R
  • GoT BoosT!
Re: My golf mk4 1.8t
« Reply #1 on: 22 March 2015, 16:25 »
Very nice
Golf GTI ... What else would you have?
Offline shaft69
« Reply #2 on: 22 March 2015, 17:25 »
Thanks a lot more to come yet!! Wait till see my water meth set up!!
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline shaft69
« Reply #3 on: 28 March 2015, 13:46 »
Pistons are in also new oil pump and strainer, some new goodies from states thanks to my nephew in NYC.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline th3_f15t
« Reply #4 on: 29 March 2015, 16:38 »
Some good work and I defeating choice of brands being used. I like where this is going...
Moving over to Flickr, sorry for the broken picture links!
Offline shaft69
« Reply #5 on: 01 April 2015, 20:26 »
My supertech  race exhaust valves have turned up at last.
« Last Edit: 02 April 2015, 00:07 by shaft69 »
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline shaft69
« Reply #6 on: 04 April 2015, 21:00 »
Super tech high temp stem seals and race valves fitted, cyl head fitted with ARP bolts, new cambelt kit and manifold with turbo mounted. Waiting for comp housing clamp from garrett so can remove wastegate mount.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline barrym381
« Reply #7 on: 04 April 2015, 21:08 »
that lot would look great in my 4mo  :smiley:
Offline shaft69
« Reply #8 on: 18 April 2015, 17:44 »
Changed few things now using large port head so new valve cover, direct meth jets fitted and turbo lines.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Scott-R
  • GoT BoosT!
« Reply #9 on: 19 April 2015, 10:40 »
Very nice again
