Author Topic: Car died on me.  (Read 16353 times)
Offline corgi
Re: Car died on me.
« Reply #20 on: 24 March 2015, 15:02 »
VW Master Technician didn't find anything other than a possible loose connection on a sensor.
I can believe this. A loose connection can pass an "improbable value" to the ECU which to protect the engine will go into limp mode. I've not had this on the Golf but a couple of times on previous cars, most notably my Jag S-Type-R which dropped to tick-over only in the middle of a junction at rush hour. Like a Windows Laptop... turning it off and back on again cured the issue and it never happened again in my ownership  :smiley:
Corgi
Offline mcmaddy
Re: Car died on me.
« Reply #21 on: 24 March 2015, 18:43 »
Yes you can clear individual faults.
Do you know how Chris?
Anything I've looked at looks like its going to clear the whole lot.
Make a note of the different controllers that are throwing up errors. Actually as I'm writing this I've realised what you might mean ie multiple faults within the same controller? If so then you can't clear individual ones within the same controller only different controllers. My fault sorry.
Offline p3asa
Re: Car died on me.
« Reply #22 on: 24 March 2015, 18:52 »
No you were right, I'm sure the faults are on different controllers.
But when I go to click "Clear faults" I get the impression it wipes all faults which I'm reluctant to do.
Offline mcmaddy
Re: Car died on me.
« Reply #23 on: 24 March 2015, 19:31 »
If they are on different controllers then when you clear the faults it only does it on the individual controller. If you do an autoscan and clear the codes it clears all of them.
Offline p3asa
Re: Car died on me.
« Reply #24 on: 24 March 2015, 21:03 »
Cheers Chris. I'll give it a go tomorrow when I'm off.
Now been running the car for the last couple of days with no box and no error messages  :smiley:
Offline ajmoir36
Re: Car died on me.
« Reply #25 on: 24 March 2015, 21:10 »
Open each control module and there is fault code button for each one. Which then opens  another dialog which can clear that modules fault code.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline p3asa
Re: Car died on me.
« Reply #26 on: 24 March 2015, 21:19 »
Cheers.
Offline p3asa
Re: Car died on me.
« Reply #27 on: 06 May 2015, 22:22 »
I decided to leave all my error codes on the car and took it in for a service.
When I got it back they said there were no errors on the fuel system.
I thought they were at it and showed them my errors from VCDS.
They then brought the paperwork out and showed me the errors they had.
They had all my errors apart from the Fuel Rail / System pressure - to low and Fuel Pressure Sensor - Implausible Signal
I was asked if it was the ODIS system I was using and when I told them no it was VCDS / Vag Com, they said they hadn't heard of it.
Is it possible VCDS would pick up errors that their official software wouldn't?
Offline mcmaddy
Re: Car died on me.
« Reply #28 on: 07 May 2015, 05:18 »
It does make you chuckle when they come out with 'they haven't heard of it'  :grin: :grin:
Offline p3asa
Re: Car died on me.
« Reply #29 on: 07 May 2015, 15:01 »
Yeah I know, although I suppose they aren't enthusiasts and have no need to go searching for alternative methods to access the brains of the car so it is possible  :undecided:
I just thought they were at it saying the fuel system was all right. Seems a bit strange VCDS can pick up on errors that the VW official ODIS system can't.
