Author Topic: mk4 golf brake issues  (Read 3249 times)
Offline Thatcham
« on: 10 March 2015, 21:34 »
 brake problems
Hello ,
 mk4 gti turbo 1999 replaced rear pads , loosened master cylinder cap , used wind back tool replaced pads put back together all good , then brake pedal spongy so eezi-bled system in correct order no bubbles in system all runs clear with new dot4 ,but still spongy brakes are crap and fronts seem to being doing all the work , no leeks on car so what the hell is going on - really need help or its torch time !!!!
Offline Dalo Harkin
Re: mk4 golf brake issues
« Reply #1 on: 12 March 2015, 16:31 »
have you checked you connection pipe to the master cylinder hasn't come out/ loose
Offline Thatcham
« Reply #2 on: 12 March 2015, 17:07 »
I haven't but I will do this - do you think I should bleed the 2 bleed nipples on the master cylinder maybe ????
 any help would be really appreciated , many thanks
Offline gm8
« Reply #3 on: 12 March 2015, 18:56 »
worst brakes ever to bleed in my opinion , yes bleed the MC but getting a decent pedal can take a lot of fluid. ABS pump may need bled also
Offline Thatcham
« Reply #4 on: 12 March 2015, 20:10 »
right ill give that a go , and yes nearly done 2 litres of dot4 already ! still hopefully ill suss it - thanks again for the help much appreciated
Offline Chris.
« Reply #5 on: 21 March 2015, 23:30 »
Shouldnt need to bleed if you only swapped pads.
Click For Build Thread
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 22 March 2015, 21:42 »
Indeed. I've just fitted and bled my Brembo 4pots and got a decent pedal, it took me 3 attempts on each caliper and the master cylinder though. I still think I can get it better but I'm giving it a week to shake up any air left in there...
