Author Topic: Are the EXTENDED WARRANTY'S worth it ?  (Read 6554 times)
Offline chris1h
  • MK6 GTI BLACK 3 DOOR
« on: 05 March 2015, 20:46 »
as above. just got the letter from vw. worth it?  :whistle:
MK6 GTI - 2011 - PEARL BLACK - 3 DOOR  - 18" MONZA SHADOWS  -  RNS510/DAB  -  ACC  - SUNROOF  -  WINTER PACK  - DYNAUDIO  -  VIENNA LEATHER  - PARKING SENSORS  - BLUETOOTH
Offline chris1h
Re: Are the EXTENDED WARRANTY'S worth it ?
« Reply #1 on: 05 March 2015, 20:50 »
    Aerial and co-axial leads
    Air cleaners
    Auxiliary belts
    Bonnet, boot and fuel flap release cables
    Brake friction material and discs/drums
    Brake pipes and brake hoses
    Clutch pressure plates, bearings and frictional material
    Core plugs
    Distributor caps
    Drive shaft and steering rack gaiters
    Electrical wiring, connection blocks, terminals and fuses
    Exhaust systems (although catalytic converters are covered for internal failure only)
    Fuel filters
    All hinges
    Hoses, hose clips and connectors
    HT leads
    Light bulbs
    Non-Volkswagen original parts (or equivalent in respect of other makes) that are not of a matching quality to Volkswagen original parts (or equivalent)
    Oil filters and gaskets
    Pollen filters
    Rotor arms
    Spark plugs
    Sunroof cables, convertible roof material and straps
    Tyres
    Wheels
    Wiper blades, arms, washer jets and hoses
    Parts requiring decarbonisation, burnt or pitted valves and valve seats
That is a list of components not covered by the highest level warranty they do. Does anyone know what the timing chain tensioner would come under?
Offline Rgdogg
« Reply #2 on: 05 March 2015, 21:03 »
I have extended warranty and got the revised tensioner replaced under warranty from Vw Crosshills
Gti, Candy White, 3door, DSG, Leather, Rear LEDs, Bluefin, Milltek, vwr intake, Focal speakers.
Offline chris1h
« Reply #3 on: 05 March 2015, 21:10 »
for free?
Offline Rgdogg
« Reply #4 on: 05 March 2015, 21:16 »
I chose the warranty with £100 excess, so that's all I paid
Offline chris1h
« Reply #5 on: 05 March 2015, 21:18 »
ah sweet! hopefully thats the case if it goes! obviously hopefully it doesn't... was thinking about the 100 excess but knowing my luck car would be in for loads little jobs for under £100
Offline Rgdogg
« Reply #6 on: 05 March 2015, 21:21 »
Yeah it should be covered, if yours is 2011 model I wouldn't be overly concerned about the tensioner.
Offline Booth11
« Reply #7 on: 05 March 2015, 21:21 »
Worth it for the timing chain alone then.  I had extended warranty on on my last mk5, didn't have any issues but there if needed, so peace of mind.  If I was keeping this car longer than 3 years I'd definitely get one.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Rgdogg
« Reply #8 on: 05 March 2015, 21:23 »
Like booth says its piece of mind and if you have dsg it's definitely worth having just in case.
Offline chris1h
« Reply #9 on: 05 March 2015, 21:29 »
yeah sept 2011 model. Manual   ,you think? i know there was a revised tensioner but thought was still problems?
Yeah think it is best. carnt quite afford a r  :laugh:
